Headlamp unit removal!!
Posted: Tue Oct 16, 2018 3:43 pm
As a follow up to my last post I removed the headlamp units from the pods. A fairly straight forward job if you realise that the release tang for the chrome trim can be accessed through the drain hole at the base of the pod, I suspect most of you know this already.
One of my pods looks as though it may be a replacement as it is lighter than the other which also carries a tag B2.6 which I assume is an id number,,,see what you think.
https://youtu.be/Mk6k9uPx3GA
