Boot lid
ooh that's a long shot ! I'd wager the metal strut that runs along the rear panel is missing or bent out of shape or not riveted to the GRP.... there should be a pop rivet at each end of the metal strut thru the GRP visible behind each light cluster
RichC - Fourth Gear
Mine doesn?t have a bar across the boot at the top of the rear panel, it?s only got the one that supports the boot floor, what should it be like?
- Bigbaldybloke
Bigbaldybloke wrote:Mine doesn?t have a bar across the boot at the top of the rear panel, it?s only got the one that supports the boot floor, what should it be like?
It looks like a piece of angle iron. Some pictures of mine here (although it is carpeted): lotus-chassis-f36/tidying-the-boot-t40916.html#p286493
..and..
http://www.lotuselan.net/wiki/BEF_-_Bod ... tlock_%2B2
Part no. 33 I believe.
JonB - Coveted Fifth Gear
When I took my top brace out, the 4 bolts that mount the brace also went through the boot felt padding before going through the vertical back wall of the boot. Whether this was original I can't say but it looked l original. The felt was compressed very tightly at that point. When I reinstalled the brace without the padding it didn't seem to cause any real alignment issues for the boot lid. I left the padding out because it didn't seem right to have the bolts in shear with the padding in the mix.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
My brace bolts were through the sound insulating padding too.
- Bigbaldybloke
