+2 rear screen rubber corner joint
• Page 2 of 3 • 1, 2, 3
In the US, the locking strip is fairly universal. It is the same that was used on my 78 Chevy PU, and on my Sabra GT and Elva Mk4T Coupe, as well as both Lotus. It comes in 100' rolls.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
After taking Brian Buckland for a ride in my car, he pointed out my non mitered lockstrip. He told me that it needed to be mitered at the corners to be original. I did not argue with him, but I have seen 2 original unmolested Sprints, and they had a single joint in the lower middle.
- elancoupe
elancoupe wrote:After taking Brian Buckland for a ride in my car, he pointed out my non mitered lockstrip. He told me that it needed to be mitered at the corners to be original. I did not argue with him, but I have seen 2 original unmolested Sprints, and they had a single joint in the lower middle.
Being a Lotus I would expect that it depended on the bloke in the factory on the day... Pretty sure mine is mitred, and appears that it might even be original.
Elan +2 #0245
Exige S2 Supercharged
Elan +2 #0245
- Chrispy
Photos of mine, obviosily needs new seal fitting as seal is all dried out. You can see the filler strip is trying to straighten out in the corners and ruins the corner profile. I can't see how you can avoid that happening when fitting a single piece strip with center join. The corner seal will move and always try to straighten.
If you mitre them they may pull away at the corners leaving a messy looking gap but the corner profile should stay.
Very much down to personal preference on which looks worse when the strip ages.
- mbell
Quite a few pictures of the ?non mitred? filler strip now. Many of us saying that was the original fit. Anybody care to post pictures of mitred corners for comparison? Especially any believed to have been original? Or that have been fitted for a few years?
I?m genuinely interested to see how they both look, and survive.
Andy
Andy
Where, then, lies the answer? In choice. Which shall it be: bankruptcy of purse or bankruptcy of life?
Plus 2S
BLL 315H in white.
Plus 2S
BLL 315H in white.
- EPC 394J
Here are some pics of my Sprint and my old S3, originally all had non mitered corners although they were all replaced over time, I had the S3 front mitered when the screen was replaced but I left the Sprint continuous.
I have just had the same problem as my rear screen fell out after 30 years as the rubber was perished. I cut it up to get the correct cross section of the original rubber.
I have matched it to the rubber supplied by seals direct to part WR 937 which is 25mm wide as my original. WR63 is nearly the same but only 22mm wide so will not look correct.
Body fitting: 3mm gap
Glass: 5mm
Web: 7.5mm
WR937
https://www.sealsdirect.co.uk/shop/wr93 ... tegory=473
I hope this helps
Glass: 5mm
Web: 7.5mm
WR937
I hope this helps
- HughR
For me Buckland is wrong. The chrome locking strip should not be mitred.
I wonder what Saint Miles says.
- alan.barker
When I removed the badly weathered locking strip from my Plus2, it was continuous with the join at the bottom center.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
26-4889
50-0315N
1964 Sabra GT
- prezoom
Ditto, originally mitered rubber, continuous 'chrome'
The rubber being rotten and the 'chrome' brown when purchased in 1984, stored since 1981, so unlikely to have been replaced
I had put off replacing they rubber because it was unavailable mitered, but then lost my replacement when the car was apart, and installed the continuous.
Careful install, I find the results acceptable.
- gus
Interestingly, the rubber and locking strip is the same for my S2 front, Plus2 rear, Sabra GT
front/rear, and Elva Coupe front/rear. It is also the same profile and locking strip for old Chevrolet square bodied pickups, with exception of the 3mm/1/8" recess for the pinch weld, which is narrower.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
26-4889
50-0315N
1964 Sabra GT
- prezoom
