Lotus Elan
Fuel Filler Cap Rubber.
PostPost by: john.houston » Tue May 08, 2018 9:28 pm
Hi All
I am putting parts back on my plus 2 and I am having a problem with the big rubber seal that the flip locking cap fits into . Could anyone post a close up of their filler cap showing the rubber if possible .It may be a case that the previous owner fitted the wrong one as it seems to overlap the bodywork.
Thanks John.
john.houston
First Gear
First Gear
PostPost by: tedtaylor » Tue May 08, 2018 11:27 pm
it IS supposed to overlap the body and "envelope" the body edge.
TED
tedtaylor
PostPost by: MarkDa » Tue May 08, 2018 11:50 pm
Yes - in essence it is a very large grommet.
MarkDa
PostPost by: The Veg » Wed May 09, 2018 12:53 am
Wot Ted and Mark said:
img_20170212_173223.jpg and
New and freshly installed.
img_20170828_210430.jpg and
1969/70 Elan Plus 2 (not S) 50/2036
The Veg
PostPost by: MarkDa » Wed May 09, 2018 7:41 am
I'm guessing that John's seal is a larger overall diameter and doesn't sit in the recess.
A picture may be worth a thousand words
MarkDa
PostPost by: RichC » Wed May 09, 2018 7:52 am
they are an extremely tight fit ! Some lubrication will be required . You'll think it'll never fit ... but it does eventually 8)
RichC
PostPost by: MarkDa » Wed May 09, 2018 8:47 am
Softening it in hot water beforehand helps as well.
MarkDa
PostPost by: john.houston » Wed May 09, 2018 10:44 am
Hi .Thanks for the help and Pics .
Mark you got it spot on-- 'Im guessing that John's seal is a larger overall diameter and doesn't sit in the recess.
It fits in the hole but no matter how I rotate it it overlaps on one edge of the body -the rest being in the recess.Looks awful but as I have found lots of Lotus parts can drive you mad.I guess that when the filler cap goes in it locks moisture out.
Thanks all
john.houston
First Gear
First Gear
PostPost by: john.houston » Wed May 09, 2018 11:01 am
The Veg picture is how mine fits but the other side of the rubber sits on the bodywork about 30mm of it.
john.houston
First Gear
First Gear
PostPost by: john.houston » Wed May 09, 2018 5:35 pm
Hi All .
Job done .I was being too fussy .Its all connected and ticked off the list.More questions to come.The picture helped thanks
Cheers.
john.houston
First Gear
First Gear
