Lotus Elan
Secondary Door Seals for S4
PostPost by: webrest7 » Sun Apr 29, 2018 3:32 am
Hi all,
Have just recently discovered the Elan carries a secondary door seal.
No wonder I have been getting a draft for the last 24 years.
Dopey bugger.
I have just recently replaced the main pinchweld door rubber that goes around the opening but now I need to address the secondary seal.
The pinchweld was easily sourced in Australia and assume that the profile required for the job will also be available.
The meal strip retainers I gather will be easy for me to make.
Q1 What I need to to know is where are the seals exactly positioned on the underside of the door and their length?
Q2 Also would like to see the shape of the rubber profile so I know what to search out at the supplier?
If anyone has an image or knows where I can find one it would be really helpful.
Best Regards
Dave
webrest7
PostPost by: oldelanman » Sun Apr 29, 2018 5:41 am
The secondary seal attaches to the body above the front of the door. It's a simple L shaped strip held in place by aluminium strips and pop rivets - the usual suspect in the UK sell the parts. I'm not aware of an additional seal that attaches to the door.
secondary-door-seals-004.jpg and
Secondary door seal
S4 DHC
PostPost by: elanner » Sun Apr 29, 2018 6:51 am
PostPost by: alan.barker » Sun Apr 29, 2018 7:16 am
On my Sprint the seal is the same as in the photo by Roger and is for Elans.
For the +2 Elans it is a different profile and was not fitted to all model +2s. eg. not fitted to +2S130 but not fitted to +2S.
I think the idea is to channel water away from coming in the car rather than stopping draughts.
Draughts can be caused by no plastic membrane taped to the Door under the Door Trim Panel.
PostPost by: webrest7 » Sun Apr 29, 2018 9:52 am
Thanks gentlemen,
I figure there is enough info there to do the job.
Looks pretty straightforward.
Once again this forum proves it is a font of knowledge and generous individuals prepared to share their valuable time and experience.
Best Regards
Dave
webrest7
PostPost by: types26/36 » Sun Apr 29, 2018 10:06 am
Some more pics.
1.jpg and
2.jpg and
3.jpg and
4.jpg and
5.jpg and
7.jpg and
types26/36
PostPost by: webrest7 » Sun Apr 29, 2018 12:51 pm
Thanks Brian
Those shots give me the profile an length should be able to source here in Australia
Dave
webrest7
PostPost by: webrest7 » Sun Apr 29, 2018 1:04 pm
alan.barker wrote:Draughts can be caused by no plastic membrane taped to the Door under the Door Trim Panel.
A very good point, there is no plastic covering on my car so also will be addressed.
I reckon you have a good suggestion there.
Dave
webrest7
Users browsing this forum: matt1954 and 13 guests
