Lotus Elan
Door Handles
PostPost by: Concrete-crusher » Sun Apr 08, 2018 11:05 am
On the S3 FHC are the door handles the same as those fitted to an Austin Morris 1100
They look the same
Mine are a little pitted and buying new old stock looks cheaper than re chroming
Thanks Steve
Concrete-crusher
PostPost by: gav » Sun Apr 08, 2018 11:19 am
Sorry - cant remember the source of the handles but you do need to re use the inner part of the handle - the part that triggers the door lock on the inside of the door so don't chuck it.
I am after a pattern of these so when you remove them, if you could take a set of dimensions and let me have them I'd be very grateful.
If you need help with my description, let me know and I'll try to communicate better (!)
Many thanks
Gavin
gav
PostPost by: oldelanman » Sun Apr 08, 2018 11:36 am
Deleted ...... just noticed it's an S3 :oops:
S4 DHC
PostPost by: theelanman » Sun Apr 08, 2018 11:38 am
Yes Austin 1100....as on the early +2.......
I got a pair for mine for about ?30~40 iirc......
Just used the out side and swapped the barrels over
theelanman
PostPost by: ericbushby » Sun Apr 08, 2018 11:46 am
Steve,
They are sourced from the 1100, but need adapting. Brian Buckland`s book has a section on it, Obsolete parts, pages 81,82 and 83
Eric in Burnley
S3SE DHC
PostPost by: gav » Sun Apr 08, 2018 1:28 pm
Eric
Do you know if anyone has made up the obsolete part per chance?
Gavin
gav
PostPost by: ericbushby » Sun Apr 08, 2018 3:03 pm
Sorry, no. I just remembered seeing that section in the book.
The whole chapter is about obsolete and hard to find items.
Eric
PostPost by: Concrete-crusher » Sun Apr 08, 2018 3:22 pm
I'm happy to take some pictures and dimensions. I have ordered the Austin 1100 handles so should not take too long.
I'd be interested to see a scan of the pages referred to above if available.
Cheers Steve
Concrete-crusher
PostPost by: Concrete-crusher » Sun Apr 22, 2018 1:37 pm
I have dismantled the doors today , here's a picture of the plate for Gavin , let me know if you want something more precise
img_0391.jpg and
img_0392.jpg and
Concrete-crusher
PostPost by: gav » Sun Apr 22, 2018 5:40 pm
Thanks Steve
What I'm after is the dimensions of the fabricated lever on the back of the door handle that engages with the lock - activated by turning the key.
I anticipate it to be made of mild steel and will comprise a tube with a bent arm welded to it. The bent arm locates in the oblong slot of the door plate. This is the part I need to fabricate.
Thanks again
Gavin
gav
PostPost by: gherlt » Sun Apr 22, 2018 6:39 pm
I think you mean the remote arm. It is from an Morris 1100, front door (Source: Buckland), and it is bent "somehow" for the Elan.
Edit: and cut and welded, and holes drilled.
1964 S1 (engine ready, awainting body paint)
1967 S3 DHC (now adjusted by Brian Buckland, totally calm idle)
1969 S4 FHC (final interior stuff)
gherlt
PostPost by: theelanman » Mon Apr 23, 2018 11:18 am
I thought it was just the door handles you wanted.......
or do you need the whole mechanism?......
the handles are just a straight swap provided everything else on the door works......
theelanman
PostPost by: Craven » Mon Apr 23, 2018 12:09 pm
Piece on left is original to 1100/1300 made of die cast and difficult to modify, Lotus piece fitted, shown attached.
p1030336.jpg and
PostPost by: theelanman » Mon Apr 23, 2018 2:35 pm
I just took the split pin out took the 'lever' off and used the rest of the original stuff
theelanman
PostPost by: Concrete-crusher » Mon Apr 23, 2018 5:23 pm
Here are a couple of pictures with a measure
img_0393.jpg and
img_0395.jpg and
Concrete-crusher
Next
