Roof gutters
NYK wrote:I?m sure this is a dumb question, but do all Plus 2 have chrome roof gutters? I?m restoring a ?72 130S that does not have any, should it?
Am i the only one that thinks NOT? I've seen many without the roof gutter moldings and no holes from mounting them evident. Was not this an extra optional accessory?
TED
- tedtaylor
I think they all had them from the factory ? I suspect a few have lost them over the years. My car is late 72 & had chromed brass rails when purchased, but the chrome was not so good, it came with a pair of as new alloy rails, which are now on the car, they fitted perfectly & all the existing screw holes lined up a treat, so fit is probably luck of the draw.
Regards, Tim
Regards, Tim
- Orsom Weels
Orsom Weels wrote:I think they all had them from the factory ? I suspect a few have lost them over the years. My car is late 72 & had chromed brass rails when purchased, but the chrome was not so good, it came with a pair of as new alloy rails, which are now on the car, they fitted perfectly & all the existing screw holes lined up a treat, so fit is probably luck of the draw.
Regards, Tim
Hi Tim, I presume you don?t have the brass ones for sale do you?
Nic
- NYK
mbell wrote:Mines Oct 73 car and I think the rails are chromed brass.
Had a quick look at night and actually I think they are aluminium not bread on my car.
They do look to be a standard extrusion (flat base, curved top piece) as mentioned, maybe able to bend some carpet edge trim to the right shape?
- mbell
NYK wrote:Hi Tim, I presume you don?t have the brass ones for sale do you?
Nic
No, sorry, I don't .
Regards, Tim
- Orsom Weels
It's correct that the early cars, up to around 1970, had chromed brass rails and the later anodised aluminium.
When I restored my car over 4 years ago now I could not bring myself to drill the newly painted shell so I left the roof rails off - I've still not fitted them and happen to think that the car looks 'neater' without them.
They serve no real purpose and I've never had water come in as a result of them not being there
Jon
Jon
- jono
Hi Nic, I have a set of the early chromed brass from a Jan 69 car and a set of the aluminium from a Dec 73 late 130 model. I haven?t decided which set to keep for my ongoing rebuild which is the later car to Spyder Zetec spec with a Focus ST170 engine. Would you be interested in the remaining set?
Incidentally does anyone know which member has the the lovely blue car with silver roof, 15? minilites & MX5 seats. If it?s a zetec it?s very much the direction I?m going with mine and would appreciate contact details. I have a photo of the car which is on the ride height thread.
Cheers, Paul.
Cheers, Paul.
- Cannonpaul67
Hi all,
I know this is an old thread....however....I need a set of roof rails / gutters for my Plus 2. I have just finished the rebuild and it's finished apart from fitting the windscreen and the roof gutters.
Does any one have a decent straight pair they could be persuaded to part with...fingers crossed in anticipation.
I know this could go in the wanted section, but this thread seemed more appropriate.
Many thanks and regards to all, George.
George McC.
1968 S4 Elan dhc.(now sold)
1973 Plus2 S130/5
1994 Elan M100 S2
1973 Plus2 S130/5
1994 Elan M100 S2
- mcclelland
Hi - I may have, will have a look in the garage later...
Craig Elliott - Third Gear
Cannonpaul67 wrote:Hi Nic, I have a set of the early chromed brass from a Jan 69 car and a set of the aluminium from a Dec 73 late 130 model. I haven?t decided which set to keep for my ongoing rebuild which is the later car to Spyder Zetec spec with a Focus ST170 engine. Would you be interested in the remaining set?
Cheers, Paul.
Hi you have a PM
- mikealdren
