Elan +2 console
I'm looking into the possibility now. It would be a good addition to my line.
Frank
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank - Fourth Gear
This has got to be one of the most difficult parts the +2 console all in plastic to find.
For the +2S it's easy to make one and once it's covered in foam and the original pattern vinyl no one will know.
- alan.barker
The black plastic piece that goes from the dash , between the front seats , to the rear seats...
I think for a proper one, in plastic, the forming mold or buck or whatever, is time consuming to make. It is also large, so both making it properly and shipping it are difficult
Mini is still in one piece but getting beat up. I think I would make one of wood and have it upholstered, or one could repair the original and upholster it
- gus
Ah right, now I'm thinking that as mine is totally disintegrated and held together by the vinyl, maybe it's in order to lay fibreglass matting on the inside, using it as a kind of former. The rear section (between the rear seats) is fibreglass on mine, and it looks as good as the day it left the factory.
JonB - Coveted Fifth Gear
3D printing. Everything is possible but at what cost. That's why we rely on our larger suppliers to invest in getting parts manufactured, at great initial cost to them. See link for 3D printing.
https://hobsstudio.com/news/largest-3d-printer-in-uk/
With this technology the costs will come down in time.
Les.
Les.
- Elseezed
Ed, that looks fantastic! Great job.
I had to look uPVC up. Understand it is the material commonly used in window frames and siding...
https://www.diffen.com/difference/PVC_vs_uPVC
So, How did you make it? Does it require specialized skills and equipment? Can you pop off a hundred and retire on the proceeds?
Very nice. Thanks for posting.
Stu
Stu
Stu
1969 Plus 2 Federal LHD
The advantage of upvc is that you can shape it very easily using a hair dryer . Basically you heat the part that you wish to bend and it will retain the shape you have bent it into.
I used the original cracked console as a template and cut the upvc into the correct shapes and sizes using thin sheet for the sides , a thicker piece for the top and beading for the raised parts on top. I used the shape of the various pieces to judge where and how much to bend the individual pieces and then screwed and glued the parts together. I then trimmed the assembly as in the pictures fastening the beading on last to cover the joins in the trim on the main body.
The whole thing was quite simple except for the bit around the gear stick which was a bit of a fiddle due to the offset.
I did this about 5 years ago in an afternoon and it?s been in the car ever since and it also lifts out fairly easily for access
Hope that makes sense
Ed
Ed
EPA - Second Gear
