Mating body to chassi issues
Body to chassis clearances and fit can be a challenge and chassis mods can increase the issues. The bodies varied significantly from new and they have moved and changed dimensions over the years with heat and stress and repairs. The mods you appear to have done will shift the body slightly as the front of the rear towers normally fit tight against the body so fit and clearances elsewhere may become an issue that needs some work.
This is how I did mine. I low temperature silver brazed the reinforcing plates on the outside and and angle plates on the inside as buckling of the side flanges is the normal failure mode of the rear tower ears when running with hard race springs or on rough roads.
The plates were fitted to give the needed body fit with my body but all Elan bodies fit differently on the chassis so you need to assess what will work for your car. Body modifications may be better than doing the chassis mods differently.
Users browsing this forum: DamianB and 19 guests
