Internal mirror stick
Wed Oct 18, 2017 12:29 pm
by lotusbzz
does anybody know how this stick fits on the Elan S4 ?
it's not clear for me (... that never seen any Elan since mine arrived dismanteld) which is the top and the bottom i.e. which side is stuck into the crashpad and which one is fixed on the top frame of the windscreen.
a pic of the top and bottom attachment is apreciated.
Aiuto!?!?! Help me?!?!?!
Saluti da Italia
Paolo
Re: Internal mirror stick
Wed Oct 18, 2017 1:21 pm
by Grizzly
Have a look at this thread, it has some pictures of the op assembly
lotus-chassis-f36/elan-windshield-trim-t15112.html you appear to be missing the Cast alloy block, Spacer and securing screw.
The bottom fixing just drops through a hole in the back edge of the crash pad (through the Crash pad GRP mounting structure) then fixed with a large penny washer and nut (best using a nyloc as it's a pain to get to with the dash in place).
Wed Oct 18, 2017 2:56 pm
by lotusbzz
thank you Grizzly!?!?!
for the very quick replay?!?!?!?
the configuration of the two ends seems to be: the washer end to the top and the adjusting nut bottom.
just to double check , is this correct?
Wed Oct 18, 2017 5:04 pm
by Grizzly
Sorry no, the washer end goes to the bottom (dash end) and the adjuster end goes to the top (the adjuster should sit inside the alloy block that screws to the top of the window frame)
Wed Oct 18, 2017 5:38 pm
by lotusbzz
Great!!!
thanks
Paolo
Thu Oct 19, 2017 7:06 am
by Oziswan
Hi...
Would anyone be able to post a photo of the Upper Alloy block referred to in this post.(Mine is missing)
Many thanks
Fri Oct 20, 2017 5:22 pm
Alloy block
Sat Oct 21, 2017 12:38 am
by Oziswan
Thanks Brian.
A tricky little sucker to make. Would anyone have one for sale?.
Oz I Swan
Sat Oct 21, 2017 8:19 am
by ericbushby
Got mine from Sue Miller.
Eric in Burnley
1967 S3SE DHC
Sun Oct 22, 2017 12:49 am
by Oziswan
Thanks Eric....
Will try Sue Miller...Have tried to contact her many times in the past but to no avail.
Will try once again.
Oziswan
Sun Oct 22, 2017 11:25 am
by ericbushby
Oziswan,
In that case I suppose it may be better to try other dealers. Sue has supplied me with almost everything I wanted, but always by phone.
Eric in Burnley
Thu Oct 26, 2017 10:12 am
by lotusbzz
... I've tried to contact Sue Miller by phone, by fax, by email .... no answer ?!?!?!
I'll try by carrier pigeon
Paolo
