Lotus Elan
Internal mirror stick
PostPost by: lotusbzz » Wed Oct 18, 2017 12:29 pm
does anybody know how this stick fits on the Elan S4 ?
elan-mirror-stick.jpg and
it's not clear for me (... that never seen any Elan since mine arrived dismanteld) which is the top and the bottom i.e. which side is stuck into the crashpad and which one is fixed on the top frame of the windscreen.
a pic of the top and bottom attachment is apreciated.
Aiuto!?!?! Help me?!?!?!
Saluti da Italia
Paolo
lotusbzz
PostPost by: Grizzly » Wed Oct 18, 2017 1:21 pm
Have a look at this thread, it has some pictures of the op assembly lotus-chassis-f36/elan-windshield-trim-t15112.html you appear to be missing the Cast alloy block, Spacer and securing screw.
The bottom fixing just drops through a hole in the back edge of the crash pad (through the Crash pad GRP mounting structure) then fixed with a large penny washer and nut (best using a nyloc as it's a pain to get to with the dash in place).
PostPost by: lotusbzz » Wed Oct 18, 2017 2:56 pm
thank you Grizzly!?!?!
for the very quick replay?!?!?!?
the configuration of the two ends seems to be: the washer end to the top and the adjusting nut bottom.
just to double check , is this correct?
lotusbzz
PostPost by: Grizzly » Wed Oct 18, 2017 5:04 pm
Sorry no, the washer end goes to the bottom (dash end) and the adjuster end goes to the top (the adjuster should sit inside the alloy block that screws to the top of the window frame)
22365198_470575606659492_37107dsvdsvdsvds162_n.jpg and
PostPost by: lotusbzz » Wed Oct 18, 2017 5:38 pm
Great!!!
thanks
Paolo
lotusbzz
PostPost by: Oziswan » Thu Oct 19, 2017 7:06 am
Hi...
Would anyone be able to post a photo of the Upper Alloy block referred to in this post.(Mine is missing)
Many thanks
Oziswan
First Gear
First Gear
PostPost by: types26/36 » Fri Oct 20, 2017 5:22 pm
Alloy block
e-0002.jpg and
e-003.jpg and
e-004.jpg and
e-005.jpg and
e-006.jpg and
e-007.jpg and
e-008.jpg and
types26/36
PostPost by: Oziswan » Sat Oct 21, 2017 12:38 am
Thanks Brian.
A tricky little sucker to make. Would anyone have one for sale?.
Oz I Swan
Oziswan
First Gear
First Gear
PostPost by: ericbushby » Sat Oct 21, 2017 8:19 am
Got mine from Sue Miller.
Eric in Burnley
1967 S3SE DHC
PostPost by: Oziswan » Sun Oct 22, 2017 12:49 am
Thanks Eric....
Will try Sue Miller...Have tried to contact her many times in the past but to no avail.
Will try once again.
Oziswan
Oziswan
First Gear
First Gear
PostPost by: ericbushby » Sun Oct 22, 2017 11:25 am
Oziswan,
In that case I suppose it may be better to try other dealers. Sue has supplied me with almost everything I wanted, but always by phone.
Eric in Burnley
PostPost by: lotusbzz » Thu Oct 26, 2017 10:12 am
... I've tried to contact Sue Miller by phone, by fax, by email .... no answer ?!?!?! :roll:
I'll try by carrier pigeon :lol:
Paolo
lotusbzz
Users browsing this forum: TBG and 15 guests
