Sprint Bonnet release cable outer dimensions
Hello folks
I'm just about to sort the bonnet pull on my sprint. Ive managed to solder a new bowden inner to the old handle and also find most of the assembly, except one of the outers, In the dim and distant I seem to recall that one of them was duff, so I probably binned it.
Anyway, I intend to put the parts back as was, and need to know the dimensions of the outers, if someone could help me.
The arrangement in the attached photo (thanks to somefellow traveller on this forum) is what mine was like originally.
Bob
Bob
bloodknock - Fourth Gear
I don't know what the "correct" length for the outer cables is but, with the two support clips fitted to the cam cover rear outer retaining studs and the release catches in place on the bulkhead the routing and overall length of the outer cable is pretty obvious. The brass adjuster goes midway between the two support clips so that gives you the lengths of the two pieces.
Edit:- Just found a Service Bulletin on the bonnet cable. If it was carried out on your car you may only have one cable support bracket not two - might save you hunting for something you don't have
http://www.lotuselan.net/wiki/Bonnet_Catch_(Elan)_and_Cable_(Elan_and_Plus_2)
S4 DHC
S4 DHC
- oldelanman
