New parcel shelf
I have removed my old (hardboard?) parcel shelf, and would like to replace it with something a little less 'oceanic'. (wavy!!)
My choice is 6mm thick mdf. Stiff but thick! (Oooh-errr!!)
Or 3mm plywood. (similar thickness to the original high quality (not!!) hardboard.) Thin but a little wobbly!
To be honest, my preference is the thicker mdf, but I wonder whether anyone has encountered problems with a thicker parcel shelf? I suppose I'm thinking particularly of the geometry of the metal clips that sit under the window rubber of the rear screen, to support the shelf? But there may be other issues I'm too stupid to have yet considered!
Really appreciate any advice from folks who have done this job already.
Oh, and mine is an S model with the rectangular speakers in the parcel shelf. Which obviously don't work, but I would really like to replace them with something as close to the original as possible. Any ideas?
Kind regards.
Andy F.
Kind regards.
Andy F.
Where, then, lies the answer? In choice. Which shall it be: bankruptcy of purse or bankruptcy of life?
Plus 2S
BLL 315H in white.
Plus 2S
BLL 315H in white.
- EPC 394J
I can only really comment on the earlier +2. So may be wrong with some of the detail. I have the original panel, but something to consider with a thicker panel??
Will the rear seat back sit a little too high ?
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
I'm not sure it will?
Without looking too closely, the only area I would anticipate a problem, seems to be the clips under the rear screen?? That's the question I'm asking.
I have a 69 Plus 2 S, with the fold down rear seat.
Thanks.
Plus 2S
BLL 315H in white.
Plus 2S
BLL 315H in white.
- EPC 394J
I did 3mm ply myself....
there is a curve in the parcel shelf... that has been lost over time... it's all wavy by now.. but when you use ply it is straight and looks great until you try and get it into the clips... I had a big gap in the centre... so I used some old hose on top of the petrol tank to bend the ply into position.
Not as designed... I cannot use the clips anymore... I would use a piece of hardboard... alot more forgiving.
LaikaTheDog - Third Gear
On my car the rear clips are just metal bracket that fit under the seal and the shelf sits on wedged under the seal. So I wouldn't have thought a few mm would make much of a difference but my seal is pretty shrunken at present (will replace it soon). Car is a +2S130 so might be different early cars.
Personally I thought of making a new shelf and using "plastic cardboard" as used for signs etc. I suspect it would be lighter than MDF and possibly hard board, while being more rigid than hardboard. It could also be easily slotted to slide the bracket between the two outer surfaces, negating any extra thickness and making it more secure.
I'd also swap out the heavily steel L bean for some Aluminum L, to save some more weight.
- mbell
I see what Laika means.
Perhaps you can see it in this photo?
Looking along the flat top of the fuel tank, you can see the rear of the parcel shelf has to be bowed up in order to slip onto the clips and fit snug to the bottom of the rear screen.
The front edge of the parcel shelf (seat back) is held dead straight by a piece of angled metal.
Hardboard it is!!
Hardboard it is!!
Plus 2S
BLL 315H in white.
Plus 2S
BLL 315H in white.
- EPC 394J
Hi Trevor
That looks great. Nice clean car too. Unlike mine!
Were you able to fit the plywood into the clips ok! I see you used basketweave vinyl? Mine's currently just the usual grain vinyl. Also I don't have the bar that appears to go on the top of yours.
Many thanks.
Andy
Many thanks.
Andy
Plus 2S
BLL 315H in white.
Plus 2S
BLL 315H in white.
- EPC 394J
Hi Andy.
Yes plywood fitted into the clips ok, the rear rubber and screen now fitted and no problems.
My vinyl is the original one and refitted.
I replaced my rear shelf because it was warped and the sponge had become yellow dust. I used plywood because it?s stiffer than hardboard, but used hardboard for new door panels as it curved better and held position with the new clips and ?Snapsac? (plastic bushes).
The Rear seat squab hooks over the angled bar, it also stiffens the shelf.
Hope it goes well for you.
Trevor
1968 Elan +2 50/0173
TeeJay - Fourth Gear
The Rear seat squab hooks over the angled bar.
Ah, mine has the fold down seat back. That must be the difference. Really appreciate your input. So it looks like the hardboard's on it's way back to the shop, to exchange for 3mm ply!
Plus 2S
BLL 315H in white.
Plus 2S
BLL 315H in white.
- EPC 394J
I've got some 1/4" ply, of something nicer than the usual pine (but I forget exactly what) waiting to become a new shelf. I'm looking forward to getting that done.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
[quote="EPC 394J"Ah, mine has the fold down seat back. That must be the difference.[/quote]
The fold down rear seat back needs the angle brace also. It's a different part number in the parts manual and mounts on the under side of the shelf, aligned with the front edge. Your's has that one doesn't it?
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
It does indeed.
Not sure whether to reuse my original vinyl, which looks ok, or buy new??
I definitely want to reuse my speaker grills, but they will need prettying up!
Plus 2S
BLL 315H in white.
Plus 2S
BLL 315H in white.
- EPC 394J
EPC 394J wrote:Not sure whether to reuse my original vinyl, which looks ok, or buy new??
Andy, if the replacement shelf is the same thickness as the original, mine was 3mm and the original vinyl is in good condition, then I would reuse it.
If you used thicker shelf material you may have difficulty having enough material to wrap round onto the bottom to secure it.
I washed mine with soapy water and scrubbed into the basket weave, mainly to remove dust and then when rinsed and dry, used Meguiars Gold Class Trim Detailer. I?ve used this product on most of my black vinyl / plastic interior; it restored original richness to discoloured black items.
Today we are spoilt for choice with products for restoration.
Trevor
