Vacuum pods S3
Recently I bought my first Lotus, a 1967 S3SE DHC. My questions is about the vacuum pods: The vacuum from the engine is routed via the vaccum dash switch to the LH pod and from there to the RH pod. Is the vaccum of the RH pod dependent on the LH pod, or is the vaccum line split in the LH pod? My LH pod is not working, but the RH is, so I wonder how this could be.?..Most likely a stupid question...
Thank you!
Phil
Thank you!
Phil
- phil1800
If the LH pod is not working and the RH one is, I would guess that either the inlet pipe of the LH pod is clogged up or the rod that pokes out of the top hole has become disconnected from the diaphragm inside.
It is unlikely to be a split diaphragm or a hole in the lower metal case as that would tend to let the ambient air in and prevent the other pod from working.
lotus-chassis-f36/vacuum-pod-repair-t25234.html#p164248
Check the system for leaks - usual place is the Tee piece on the front crossmember which is the vacuum reservoir - and also check the pods are moving freely on their pivots. Low vacuum and a stiff LH pod could combine to produce your symptoms.
S4 DHC
S4 DHC
- oldelanman
If your LH pod is not operating but the RH one is, that tells me the LH one is holding vacuum, so your problem must be in the operating links between the vac chamber and diaphram and the headlamp pod. I suppose it could also be something locking the pod from pivoting on its axis. Can you raise the headlamp by hand against the spring force?
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
