Lotus Elan
Replacement Crash Pad
PostPost by: RichC » Thu Jul 06, 2017 7:24 am
here u go
img_1001.jpg and
RichC
PostPost by: wotsisname » Thu Jul 06, 2017 3:03 pm
RichC wrote:crashpad is not material backed but vacuum formed rigid plastic . the bits you're asking about are vinyl covered material but a slightly heavier grain than on the seats i think ....easy enough to source and fix.
As RichC says -
definitely hard plastic, with a grain (possible some kind of heated stamp used ?), was used for the crashpad.
The under dash edge trims are vinyl folded over neoprene/foam material and glued to a metal channel, which is screwed into the back of the dash. I had to recover the rear side panels and used the same vinyl for the under dash edges { I got the closest match I could, from Martrim in the UK, the new stuff is not as thick as the original). I also have some left over to do the panels which cover up the wiring/heater area (forward of the central console).
1968 Elan plus 2 - project
2000 Elise S1 - Sold
wotsisname
Previous
Users browsing this forum: greg40green and 10 guests
