Carpets
Hi Mikael,
Try Sue Miller at http://www.mickmillerlotus.com/intro.html
Or
Paul Matty https://paulmattysportscars.co.uk/lotus-parts-online/
Or
Sj Sportscar http://www.sjsportscars.co.uk
Or
Or
Grizzly - Coveted Fifth Gear
I also used Mapei Ultabond Eco VS90 adhesive which was really good , but then I work for them but not in that section of business.
- Concrete-crusher
I can recommend Coverdale - good prices and choice of quality and colours.
You can buy what you need and loose carpet/underlay.
They will.either copy your carpets of work off standard patterns.
They are pretty busy so delivery is a few weeks.
- MarkDa
Definitely make your own. Use brown paper or cardboard for templates, trim to fit and then cut your carpet. Seal the cut edges carefully with a pain stripping heat gun or have someone sew edging to them for you, though heat sealing always works for me. I use modern 1/4" soundproofing underfelt cut slightly undersize. For gluing, Dunlop Thixofix or other slow contact adhesive. Your carpets will fit perfectly and you will be very satisfied at your achievement! When you do the panel at the back of the cockpit make sure you keep it in the right shape to go back as you glue the carpet or you will have a little difficulty fitting it back in, and don't forget to cut the holes for the seat belts and put them through first!
Nigel F.
Nigel F.
- nigelrbfurness
