Check strap seal/grommet?
Hi all.
Does anyone know how where i can get hold of a pair of S4/Sprint check strap seals? I was tempted to leave them off but after a quick wash this morning i've noticed quite a bad water leak from that area so i guess they will be going back on (assuming i can get some).
I tried Sue but was busy so have had a quick look on Paul Matty and SJS web pages but couldn't see any.
Grizzly - Coveted Fifth Gear
Not had any luck getting through today, had a look through her catalogue and couldn't find any listed...... Sods law i'm going to be busy all day tomorrow too so might be Wednesday before i can have another go
Let me know how you get on.
Try RD Enterprises in the USA, he has lots of grommets
mark030358 wrote:Try RD Enterprises in the USA, he has lots of grommets
just had a look on Ray's site : ref 36B6167 is listed for that purpose (among others) but these are not identical to the original, just plain grommets (" 3/4" ID fits 1" hole 1-3/16" OD wide groove to accept fiberglass panel thickness ")
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Couldn't find the grommets I needed for the Sabra restoration. So I made some molds, purchased some 2 part liquid silicon, and made my own. All but one of the holes in the body were 1 inch in diameter. The other was for the main harness to go from the passenger compartment to the engine compartment. To ease the making of multiple different grommets for different applications, I made one grommet that had no hole. A recess in the back of the grommet of 3/4" in diameter, when fully opened up, was large enough for the heater hoses. The rest were hole punched for the diameter of what was to pass through them. Unpunched grommets plugged unneeded holes.
Took several tries to get a grommet of the needed hardness so as not to fall apart during installation. If my memory serves me, I think I settled on a durometer reading of 80. Also made a mold for casting pedal pads for the clutch and brake, as these were NLA. The molds can be made of aluminum or wood. If metal, a mold release agent just needed to be sprayed into the mold. With wood, a varnish coating would be needed before the mold release agent is applied.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
I thought about doing that myself but i i'm not sure i like the idea of the seal being inside the car.
I've spent hours searching our stores at work with little luck, i found some Mk2 Jag seals which look identical but the groove is too narrow, that said i took the door off yesterday and on closer inspection i can see why the original grommets wouldn't stay in position (the GRP is very thick around the hole) so if i have no joy in the searching my fall back plan is to cut the inside edge off the two grommets i found and PU glue them into position, bit rough way of doing it but will at least look as it was meant too while stopping the leak.
One other issue i noticed was my Check strap tube on the drivers side doesn't sit in the centre of the hole in the body which is odd...
I went to the Beaulieu Autojumble yesterday and there was a chap called Richard Deex Trading from Cheshire. He seemed to have quite a large stock of unusual type rubber grommets, so he may have something suitable. Telephone number is 0161-432-8435.
- William2
Small world..... i bought most of my wiring supplies from him as he's not far from me. I didn't know he did Grommets though, might be worth a call.
http://www.wiringandbulbs.co.uk/
