Wiper arm removal
Mine have a little spring latch underneath the cap that covers the splined shaft. Kinda tough to see. Crank the arm up to 90 degrees and look under the cap. It needs a small screwdriver to pry the latch away from under the splines.
Without the latch the arm could fly off.
Nick
Nick
elanner - Fourth Gear
As above, it has a little latch that sits in a groove in the wiper mechanism spindle.
Sorry not the best picture but you can see the latch under the arm pivot, you need to carefully put a flat blade screw driver between the little latch and the wiper spindle then gently leaver up to release.
Grizzly - Coveted Fifth Gear
I suppose you could use one of these...
https://www.rimmerbros.co.uk/Item--i-RX ... 7Qod9NILrw
I tend to use a flat blade screwdriver a lever it off (carefully)
- KevJ+2
KevJ+2 wrote:I suppose you could use one of these...
Aren't those pullers for the more modern type of wiper arm with a nut/stud fixing in the centre?
Grizzly wrote:KevJ+2 wrote:I suppose you could use one of these...
<a class="vglnk" href="https://www.rimmerbros.co.uk/Item--i-RX1954?gclid=CKCnmcuL4NMCFWm-7Qod9NILrw" rel="nofollow"><span>https</span><span>://</span><span>www</span><span>.</span><span>rimmerbros</span><span>.</span><span>co</span><span>.</span><span>uk</span><span>/</span><span>Item</span><span>--</span><span>i</span><span>-</span><span>RX1954</span><span>?</span><span>gclid</span><span>=</span><span>CKCnmcuL4NMCFWm</span><span>-</span><span>7Qod9NILrw</span></a>
I assumed because Rimmer Bros were selling them, they would be for older wipers, but yes, I think you're right...screwdriver it is then
- KevJ+2
KevJ+2 wrote:Grizzly wrote:KevJ+2 wrote:I suppose you could use one of these...
I have a few of these http://www.ebay.co.uk/itm/BOJO-Plastic- ... xygPtS8i3Q they are good for removing trim etc without leaving witness marks but i'm not sure it would be strong enough to move the little latch (worth a go though as it doesn't tend to leave big scratches if you slip)
A couple of layers of masking or insulation tape around the end of a flat blade screwdriver can be a useful tool... something to take the edge off.
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
They came right off and I'm pleased to report that the splines are in excellent condition!
Follow-up question: is there supposed to be a gasket or seal of some type between the escutcheon and the body?
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Yes there is supposed to be a rubber seal/washer.
I bought mine from Rimmer Brothers (Same as the a few Triumph's) or the kits can be found at all the usual suspects or ebay http://www.ebay.co.uk/itm/WINDSCREEN-WI ... SweW5VHR1~
I suspected as much. There was nothing under one and some chalky black residue under the other that I figured had once been some kind of gasket.
Looks like I can get the gaskets from sources here in USA for about a dollar a piece but then another nine dollars for postage! Bloody hell, as small as the things are they could just put a couple of them in a letter-size envelope with a single stamp.
Lucky me though; today I was poking around the shelves in the workshop at the office and found some black sheet-rubber that had been left over from something long ago and never discarded. I'll make a pair of gaskets, FREE!
2012 BMW R1200GS
2012 BMW R1200GS
