Setting Suspension +2 after Full Rebuild
Posted: Tue Mar 21, 2017 10:43 am
A question was raised; in a different thread; re Setting Up the +2 following a full rebuild.
In my case, new chassis (Lotus), New shocks, new suspension bushes, trunnions etc, etc.
In the +2 Workshop Manual, in the Overhaul and Rebuild Section, see (e) of the attachment, it says to Load the Vehicle on the Front to Rear centre line, with the stated weights.
Now this has been interpretated in 2 different ways.
1) Split the weight stated by ? and place each on each seat. i.e. 84lbs on each Front seat.
2) Place the full weight stated on each of the seats. i.e. 168lbs on each Front seat.
The total weight in the car prior to tightening up wishbones and suspension mountings is very different.
i.e. in 1) Total = 370lbs. In 2) Total + 618lbs.
Which is correct?
In the original thread, Rohan posted his suggestion, which was a different method to set it up.
I am very grateful for his contribution and will follow his very experienced advice.
Having recently goggled this subject, I did find on another Lotus forum, someone suggesting using ? of the human body weight of a car of 2 Adults and 2 Children. This would suggest the answer as in 1) above.
But I am very curious to see how others understand the instructions in the Workshop Manual.
Which is correct?
