S3 Door Lock not working
Wed Oct 19, 2016 11:33 am
by Galwaylotus
The passenger side door lock on my S3 SE FHC won't stay locked! For a while it would only lock by using the inside opener lever but now not even that works. I took off the lock cover and watched while turning the key. The lock plate moves as it should but apparently not quite far enough to stay in the locked position so when I turn the key back to centre to remove it the door is unlocked. Has anyone experienced this and is there a simple fix (other than replacing the lock)? I looked in the archives but didn't see anything for this issue. Thanks, folks.
Re: S3 Door Lock not working
Wed Oct 19, 2016 11:42 am
by AHM
Have you checked the position of the child lock to see if that is interfering?
It is by the gear shaped catch in case you were wondering!
Wed Oct 19, 2016 12:26 pm
by Galwaylotus
I wasn't aware of there being one! I'll look at it later when I can get back to the car. Thanks.
Wed Oct 19, 2016 2:34 pm
by theelanman
any pics of the 'child' locks?
Ive never noticed them either......
Wed Oct 19, 2016 4:31 pm
by seniorchristo
WD 40 solved all my door lock and latch issues. I was amazed!
Wed Oct 19, 2016 4:58 pm
by Galwaylotus
seniorchristo wrote:WD 40 solved all my door lock and latch issues. I was amazed!
WD40 Antifriction Dry PTFE spray!!
