S3 Door Lock not working
The passenger side door lock on my S3 SE FHC won't stay locked! For a while it would only lock by using the inside opener lever but now not even that works. I took off the lock cover and watched while turning the key. The lock plate moves as it should but apparently not quite far enough to stay in the locked position so when I turn the key back to centre to remove it the door is unlocked. Has anyone experienced this and is there a simple fix (other than replacing the lock)? I looked in the archives but didn't see anything for this issue. Thanks, folks.
'67 S3 SE FHC
'67 S3 SE FHC
I wasn't aware of there being one! I'll look at it later when I can get back to the car. Thanks.
'67 S3 SE FHC
'67 S3 SE FHC
any pics of the 'child' locks?
Ive never noticed them either......
WD 40 solved all my door lock and latch issues. I was amazed!
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
seniorchristo wrote:WD 40 solved all my door lock and latch issues. I was amazed!
WD40 Antifriction Dry PTFE spray!!
'67 S3 SE FHC
'67 S3 SE FHC
