Lotus Elan
Don't lean on the ******* door when you get out!!
PostPost by: bigvalvehead » Fri Sep 23, 2016 7:20 pm
Pit stop of the Goldbug recreation at Spa classic 2016
https://youtu.be/6HNd-N6jSg4
Dave Hughes
Dave Hughes
S2 26R
Elan DHC Sprint
bigvalvehead
PostPost by: toomspj » Fri Sep 23, 2016 8:17 pm
Ho hum - makes me feel a bit better about some of my pitstops!
Turning money into noise!
toomspj
PostPost by: pharriso » Fri Sep 23, 2016 9:07 pm
Judging by the way they put it back this is not the first time it has happened :?
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: elansprint71 » Fri Sep 23, 2016 10:41 pm
... and the green stripe is an inch too narrow... iirc. Just saying...
PostPost by: nmauduit » Sat Sep 24, 2016 6:23 am
side effect of the super lightweight panels ? he did not lean that heavily...
S4SE 36/8198
PostPost by: patrics » Mon Sep 26, 2016 8:10 pm
"Judging by the way they put it back this is not the first time it has happened"
Judging by the way it was put on is probably why it fell off! - didn't look like he put any weight on that what so ever!
patrics
PostPost by: denicholls2 » Mon Sep 26, 2016 10:27 pm
patrics wrote:Judging by the way it was put on is probably why it fell off! - didn't look like he put any weight on that what so ever!
No, but what he did do was to fling it hard against the stop. This would apply significant force to pry it out of its mounts.
denicholls2
PostPost by: patrics » Tue Sep 27, 2016 8:56 pm
Well have re looked at the footage and there is no way it was flung hard against the stop - no driver error there - when you open the door it is not supposed to fall off!
patrics
PostPost by: theelanman » Wed Sep 28, 2016 2:51 pm
its part of the aero package when moving and a gravity fixing when still.... :mrgreen:
theelanman
PostPost by: JohnDanbyRacing » Wed Sep 28, 2016 9:04 pm
The plastic nodules have to be TIGHT in the recess to stop this happening especially with the lightweight doors. Obviously these were not!
JohnDanbyRacing
First Gear
First Gear
PostPost by: ceejay » Fri Nov 04, 2016 8:21 pm
S2 elans and 26R doors don't have hinge check straps, but what they do or should have is a strip of high density foam glued vertically to the body/door recess behind the front part of the door to act as a soft stop...the foam prevents the doors flinging open and putting forced pressure on the bobbins. The door on my S2 flung open while going around a corner while in town many years ago, and it was just pure luck that the bobbins did not pop and the door end up on the road...how embarrassing would that be.
PostPost by: el-saturn » Fri Nov 04, 2016 9:00 pm
i dont wanna offend anyone, but at donington (ef) any FF team would look 10times more professional: a FF at 10grand (?) and the 26R at 150grand - does that make any sense!!!!????? sorry folks i even worked in F1!
Users browsing this forum: 1963 S1 and 13 guests
