Headlamp Vacuum Pod Brackets
Hi All,
How are the vacuum pods mounted to the wheel arch? (UK elan S4)
Mine seem to be held on by a bent piece of tin which has been bent out of shape!
- AHM
AHM wrote:Hi All,
Sounds about right......
S4 DHC
S4 DHC
- oldelanman
Does anyone have a dimension for the hole for the stud on the bottom of the pod?
I have the hole for the bracket shown, but have glassed over the hole for the stud.
AHM
AHM
- AHM
AHM wrote:Does anyone have a dimension for the hole for the stud on the bottom of the pod?
AHM
Well I would hate to be responsible for you drilling holes in the wrong place but here's where mine are.......
Measure inboard 100mm from the centre line of the indicator lamp then 200mm down around the curve of the body from the lower edge of the bumper recess.
S4 DHC
S4 DHC
- oldelanman
oldelanman wrote:AHM wrote:Does anyone have a dimension for the hole for the stud on the bottom of the pod?
AHM
My S2 is similar. Can you shine a torch through the area to locate the original hole?
Meg
I've been successful with a light for other holes.
The problem here is that they have been ground, filled, and glassed out of existence.
- AHM
