Console on Elan +2S
PostPosted: Thu Dec 15, 2005 10:16 am
by cdraper
The console on my +2 is very "shaky" and having removed it I find the the mylar body is in a hundred little split pieces. CN do list new consoles but say they are unable to supply do to probelms with the fibreglass shell. Clearly a fiblerglass shell is a better idea than a mylar one. I have considered using fiberglass to repair the original - or gluing in plywood.
Has anybody else had a similar problem and what fixes are recommended.
Does anybody else make the shell - Nick Millar - Spyder ?????
Re: Console on Elan +2S
PostPosted: Fri Dec 16, 2005 3:54 am
by bengalcharlie
I bought a fibre glass replacement from paul Matty years ago and had it recovered.
the fitting was surprisingly good.
hope this helps
Robin
69 stromberg elan plus two
PostPosted: Fri Dec 16, 2005 4:39 am
by berni29
Hi There
I know the sort of cracking you mean. I am sure that it could be fixed with fibreglass. Sheet aluminium would be easier I guess.
Berni
PostPosted: Sat Dec 17, 2005 2:54 am
by 72plus2
I have a simmilar problem with the under-dash trim, especially around where the fog lamp switches are mounted. To repair I laid up fibreglass directly behind the exising material, or on to a tin jig, then re-glued the nylon to it. This worked well.
Chris
PostPosted: Sat Dec 17, 2005 11:36 am
by simon.mitchell
Spyder make the shell and will re-cover it for you too if you want - They did mine for the Zetec, which has the gear lever slightly further back from standard, and I was pleased with the result. Can't remember how much, but I don't think it was hugely expensive. I'm sure that they'd do a standard one for you if you give them a call.
PostPosted: Sun Dec 18, 2005 8:57 pm
by Si_130/5
Hello cbdraper,
Plasticard and Evo Stick Contact is excellent for reinforcing localised cracking and, if it's sufficiently thin and flexible, holding together the splits found along the ninety degree edges of the centre console and black under-dash trims.
Hope this helps,
Si
