When were the Airflow vents added to the Elan Coupe?
The airflow Coupes begin somewhere around #36 6200. I have seen some pre airflow cars in the late 6100's, and the Elan registry shows #6248 as an airflow car.
As with most things Lotus, it's pretty inexact, so I am sure that there is info to the contrary.
- elancoupe
Hi Woody
Mike (elancoupe on this forun) has 36/6138 without vents and I have 36/6292 with the first form of Elan airflow vents. That said there are no way of really telling whether there was a set date/unit number of when it changed. Not much occured at Lotus in that time period when you can be certain of a change over date. I don't believe that the records that Lotus has kept even specified whether it was a type 26 (Roadster) type 36 (Coupe) or type 45 (Drop Head Coupe). I guess a safe bet would be if the Coupe is before 36/6000 it is a pre-airflow, but I wouldn't put and real money on any "definent" statement about Lotus at that time. If you are looking and it matters that much you will have to ask the owner selling the Coupe.
Gary
Gary
RichardS wrote:According to "The Original Lotus Elan" by Robinshaw and Ross "revised quarter panel grille apertures on FHC" were introduced in March 1968.
That date ( March 1968) is the introduction of the S4 Coupe, it says in the back of the same book under ?production milestones? that at 5811 ?Airflow ventilation introduced on FHC with body quarter panel extractor grills?. So, wrong again I am with my 36/6000 statement. Mike?s Coupe is clearly a much later number and so as I said I wouldn?t bet any money on anything definite at Lotus at that time. Here are some photos for all 3 types of Coupes. pre-airflow, S3 airflow and S4 airflow. The S3 Airflow needs to be a bit better to show anything so I will replace it later.
- Attachments
Thank you for all this information, and so soon after I posted my question.
I guess I have to adapt my way of thinking. I'm used to looking at American car where I can say, "Okay, I want this feature, so I need to look for a 65-67".
Incidently, I'm from Connecticut.
- Woodyhfd
When you're checking cars out, Woody, the early pre-airflow also had the window switches in the door rather than on the dash, and had aluminium kick plates on the front of the door trim, rather than carpet.
The early cars should have the woodrim steering wheel, whilst the later ones had a leather covered wheel, but I don't think that the break point was the airflow!
I had 36/5246 for a while, but then (in the 1980s) didn't really appriciate what I had. It had the Marston radiator with the twin spring bonnet (hood) connectors, and I wonder now, were those fitted all the way through to the airflow model? I somehow doubt it...I guess they were just using up the common parts as the S3 was being built alongside the S2 roadster.
Anybody know of a later car with the Marston?
Last edited by Elanintheforest on Tue Mar 25, 2008 11:05 pm, edited 1 time in total.
And, slightly off topic, talking of woodrim steering wheels, have you all seen this?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=012
It was posted at ?510 for most of today, but I notice Bidder No 3 is now missing, presumed consumed by the fleabay police? Currently at a mere ?310
trw99 - Coveted Fifth Gear
Looking superb, Ken, and living proof that nothing is absolute in the Elan world. Your car does remind me though...the early cars also has S2 trunk hinges...when did they change??
I wonder if your car took so long to register because it was the last of the non-airflows...sat alongside an airflow in the showroom it may have been a little obvious.
By the way, does it have a Marston radiator?
Elanintheforest wrote:When you're checking cars out, Woody, the early pre-airflow also had the window switches in the door rather than on the dash, and had aluminium kick plates on the front of the door trim, rather than carpet.
My late pre airflow ( 6138) has the window switches in the dash and has (had) the aluminum kick plates. It also came with servo brakes, and 3:55 diff.
- elancoupe
Made June 1966 and registered in St Louis in 1967. 36/5785 and had aluminum door kick plate and the S2 boot hinges. The original color, later changed to BRG.
Sarto
Sarto
lotus elan 1966 S3 FHC
36/5785
LHD
36/5785
LHD
mac5777 - Fourth Gear
