Will I Lose My Bonnet?
Could some one please post a picture of the bottom attachment point for the two springs on the S2 bonnet? The PO attached the springs at an angle, which does not allow the bonnet to raise at the back when the latches are released. The Buckland book discusses this point, but does not include a picture of the lower attachment points.
Rob Walker
Rob Walker
- 264889socal
I just found 2 stout springs at the hardware store ---ed
Thanks so much. Makes perfect sense to make the attachment point at that location. Will make the change and now, just maybe I won't have to try to wedge my fingers between the body and the bonnet to raise it up.
Rob Walker
Rob Walker
- 264889socal
264889socal wrote: ..... just maybe I won't have to try to wedge my fingers between the body and the bonnet to raise it up.
Rob Walker
Mm - I keep a toothbrush in the glove box; the plastic handle is just about perfect for running along between the bonnet rear edge and the scuttle to persuade the catches to unhook. Technology provides the answer every time.
- hatman
I had the same problem, fitted a 26R alloy rad and a modern electric fan- could not get to the rack.
I fitted a small stainless steel fairlead (from a yacht chandlers), this is basically an omega shaped piece of steel with two screw holes. This is bolted through the glass firbe in front of the rack, small ally plate on the underside as a load-spreader. Spring is fitted through this- works great. If you want I'll photograph it.
I also fitted bonnet pins at the rear as I found it less than amusing when the bonnet popped open a few times at exactly 100mph!.
Pete
Pete
rgh0 wrote:I removed the spring on my Elan bonnet many years ago as I got sick of trying to pull the spring off every time I opened the bonnet and got sick of holding it open with my head.
I put a strip of rubber foam on the fromt lip of the bonnet to hold it firmly down and stop the bonnet rattling.
As its a competition car I also use bonnet pins in place of the standard catches so its easy to pull the pin clips, push down on the front of the bonnet and the back pops up and it can be removed all in about 1 second. Without the pins its a lot harder to open a bonnet with the standard catches and loss of the bonnet much more likely.
Thinking of doing same thing to my S4. Rohan - do you have any pictures of the brackets you use to hold the pins to the bulkhead? Looking at your photos I’d guess your pins are located about where the factory bonnet catches were? If so, that’s where I’m thinking as well.
- s3swiss
Users browsing this forum: smiths everest and 34 guests
