Any idea what this is for?
This is what my early plus two jack looks like. Also shown in operation in the owners handbook!
- ncm
If you do not want the jack handle stick it on ebay, I will bid mine is not to good.
Jason
Jason
Jason1 - Coveted Fifth Gear
I have the rachet jack system on my +2..
Works OK and seems more stable that the scissor jacks I have used before although it is true if the rachet jumps you can end up punching the tarmac!
tdafforn - Fourth Gear
Jason, I'd feel awful taking money from a fellow board member. Tell you what, I'll swap you for a Chapman steering wheel, a period radio, some seat belts and a front moustache, throw in a couple of fully trimmed door cards as well (black please) and we will both have the feel good factor without involving that tacky money thing
Kenny
Kenny
- kenny
Jason1 wrote:Hi
If you do not want the jack handle stick it on ebay, I will bid mine is not to good.![]()
Jason
I bought a replacement from Paul Matty's as I still have the original jack and use it. The ratchet spring had broke on the original handle.
Karl
1970 S4 FHC SE
1970 S4 FHC SE
fasterbyelan - Second Gear
Cheers Kenny
That sounds like a bargin
I have a couple of spare door cards that are on my list to re-back. My existing ones are ok but the water has got to them and made them curl.
I have also punched the tarmac, in-fact at least once everytime I use it.
I tried to get a ratch from Matty's but they said they are not stocking them anymore
The rivets on mine have become loose so it slips. I will proberby drill them out and re-revit it or put small nut/bolts through.
Jason
Jason
Or, get an 8 point socket the right size and use a real ratchet.
Gene
- oldokie
Ha Ha
Where's the fun in that???
If I wanted an easy life I wouldn't have bought an almost 40 year old Lotus without seeing it
Jason
Jason
