S4 DHC trunk (boot) layout
oldelanman wrote:Screw thread measures 3/16" diameter x 32 tpi (10.32 UNF ?) but if you're making one up it really doesn't matter what thread you use.
Originally this might be a 2BA screw (0.185" diameter and 31.4 threads per inch). BA screws are very common on trim pieces. Of course, as noted, you can do what you please if you are making your own.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Rick,
The genuine article can still be had. I got mine from Paul Matty in the UK.
Colin.
Colin.
YellowS4DHC wrote:Roger
thanks for the photo and specs. I figure I can just grind down a ss bolt and get a pretty close copy.
Rick
'69 Elan S4 DHC
'57 T1 Speedster
'67 S800 Coupe
'68 S4 DHC
- fatboyoz
fatboyoz wrote:Rick, The genuine article can still be had. I got mine from Paul Matty in the UK.
Colin.
Yes, that was going to be my next question. Thanks, Colin. Roger, thank you again for taking the time to post the patterns and photos. I hope to be able to make my patterns this weekend on cardboard.
I may just have the peg machined in stainless steel. Here is Roger's excellent photo, which I altered a bit to show the machine shop the thickness of the shank. Would that be about right?
Andy
- abstamaria
Roger (oldelanman), thanks for posting the pattern for the boot floor.
I made one up this weekend for my S4 DHC and the fit is good. My fuel tank is mounted slightly angled with respect to the centerline of the car, rearward portion outward (possibly modified to allow storage of a larger wheel somewhere along the line), which results in a tapered gap between the new floor board and the tank. I think I will leave it as is because I cover the whole area with a carpet anyway.
I discarded my original board some twenty odd years ago because it was an ugly, non-function-able piece (not even sure if it was plywood), fortunately I kept the two latch parts. The new floorboard makes things look much better.
Alex
45/8236
Redwood City, CA
45/8236
Redwood City, CA
Yum-yum - Second Gear
Yum-yum wrote:Roger (oldelanman), thanks for posting the pattern for the boot floor.
Thanks Alex, my pleasure. Glad it was useful to you - and a few others as well it seems. Thanks for taking the time to post your results.
S4 DHC
S4 DHC
- oldelanman
I had two pegs machined in stainless steel by a friend of mine, based on Roger's (Oldelanman's) photo. As I mentioned, my Elan was always missing this item.
Many thanks, Roger, all.
Andy
Andy
- abstamaria
Very nice Andy.
I'm sure you've already thought of it but it's a good idea to use a thin washer either side of the plywood when you fit the peg so it doesn't pull through - the spring clip holds the peg really tightly and needs a good sharp tug on the boot board to release it.
S4 DHC
S4 DHC
- oldelanman
Thanks, Roger. I won't forget to use washers.
Best,
Andy
Best,
Andy
- abstamaria
oldelanman wrote:Very nice Andy.
Yep. That's why I had to replace the board. As bought mine had a countersunk screw which was soon left behind...
- ardee_selby
Users browsing this forum: 3261R and 7 guests
