Lotus Elan
Sill kickplates
PostPost by: jonsered 11 » Wed Nov 23, 2022 11:27 pm
Hi, if you're restoring an S1 Elan you may need a pair of alloy sill kick plates, I had a small batch made when I needed them for my S1 restoration, they are £100 for a pair.
Jonsered
jonsered 11
PostPost by: nomad » Thu Nov 24, 2022 4:36 am
Do they have the correct pattern on them?
Kurt
nomad
PostPost by: jonsered 11 » Thu Nov 24, 2022 4:01 pm
I knew someone was going to ask that!!
The very first Bourne cars up to unit number 3250 had plain aluminium plates, I would imagine, knowing Lotus, that a good few cars even after that number were fitted with them to use up left over stock! I have a Lotus bodied S1 unit 3679 and it has the polka dot ones, as does all the S2s. The last 3 S1 restorations that i did had lower unit numbers than the 3250 change point so the plates I had made were plain ones, if we had a source for the Polka dot patterned material we could make the later ones also?
Jonsered
Jonsered?
jonsered 11
PostPost by: Ianashdown » Thu Nov 24, 2022 5:30 pm
Do you have any pictures of the plain and polka dot versions?
Just curious . . .
Ian
Ianashdown
PostPost by: jonsered 11 » Thu Nov 24, 2022 9:27 pm
Yes Ian, thanks for your interest,
I will send you some photos!
Jonsered
jonsered 11
PostPost by: fotsyr » Thu Nov 24, 2022 10:26 pm
I have #335, and its sills are plain.
fotsyr
PostPost by: brandon » Thu Nov 24, 2022 11:36 pm
I may be interested a well, if you could send some pictures through. Mine is #0624.
Brandon
brandon
PostPost by: zog » Fri Nov 25, 2022 11:00 am
Pictures please. And will you ship to the US?
Thanks!
zog
zog
