Lotus Elan
3.77 Quaife LSD on Mag Housing plus other bits
PostPost by: craig chima » Wed Jul 27, 2022 11:58 pm
3.77 Quaife limited slip unit completely set up in Magnesium housing. Ring and Pinion are in great shape, backlash is to spec and absolutely ready to install. $1750.00
4.11 CWP assembly. Crown wheel and pinion gear set in excellent condition. $150
Rear Axles and bits for late Lotus 7's or solid axle Caterhams: Lots of stuff here and I know not Elan-related but intended for the Lotus 7/Caterham guys who also frequent here. 4 axles, all which have been magnifluxed, with outer bearing, steel collar, and housing end cap in place. Axles also come with cryo treated rear rotors fitted (easily removable if not needed) in case someone was interested in doing a rear disc brake conversion. Also have 2 bolt on rear caliper brackets, pumpkin seals, and boxes of new bearings, seals, o-rings, etc as seen in the pix. $500 for all (pretty much a lifetime supply!) or will separate as requested.
Contact me via PM or at (330) 807-0742 or [email protected] I have lots more pix of all of the above parts and am happy to send to interested parties or discuss. Craig Chima, CC Motorsports, Akron, OH, USA
IMG_5610.jpg and
IMG_5581.jpg and
IMG_5579.jpg and
craig chima
PostPost by: TWebb » Thu Jul 28, 2022 1:32 pm
Craig,
Email sent.
TWebb
First Gear
First Gear
PostPost by: Hethel_Haus » Thu Jul 28, 2022 2:19 pm
Craig,
Likewise sent you an email.
'73 Elan +2S 130/5 Cabriolet
Hethel_Haus
