Lotus Elan
Cast iron bellhousing modified to allow gearbox removal
PostPost by: batfish » Wed Jan 05, 2022 4:56 pm
I have for sale a cast iron bellhousing that was modified by Alan Henderson Racing( Lotus Cortina specialist) to allow the removal of the gearbox without having to remove the engine. Looking for £100 for the bellhousing as it is.
Apologies I forgot that it still requires the fixing kit from AHR to enable it to be used, I can get this at cost from him if required although when I spoke to him this morning he was not sure of the price as they have to be specially machined. If any one is interested I can chase him up for a price.
Andy
batfish
PostPost by: gherlt » Wed Jan 05, 2022 5:19 pm
Hello Andy,
interesting thing, never heard of !
Would you mind posting a picture so I can understand how that works ??
Thanks !
1964 S1 (engine ready, awainting body paint)
1967 S3 DHC
1969 S4 FHC (worn engine)
gherlt
PostPost by: Slowtus » Wed Jan 05, 2022 5:41 pm
I usually removed them as a unit as I found it easier to do so, getting to the fiddly bits etc AND doing the "while I'm in there" thing but this was on Lotus Cortinas and have never split them on an Elan though I have on a Plus 2.
I think, it has been a while...
I assume that on the Elan it is an epidermis erosion event?
Slowtus
PostPost by: elancoupe » Wed Jan 05, 2022 10:28 pm
Too bad you are not in the US, I would snap this up. :(
elancoupe
PostPost by: 661 » Thu Jan 06, 2022 1:08 pm
I have these adaptations on both a cast and an ali centre case.
I have to say I'd probably not bother next time and use a magnesium bellhousing ( which can't be machined for these changes).
It is a nicely engineered solution, though. Alan Henderson does make exceedingly good cases
Graeme
S4 SE
S2 GTS
Peterson JPS Exige
PostPost by: batfish » Thu Jan 06, 2022 5:22 pm
Attached photographs of an ali bellhousing installed on my car and the inside of the cast iron bellhousing that has been machined but still requires a fixing kit from AHR.
The bellhousing to gearbox bolt holes are drilled out to have top hat sections installed which allow the bolts to be installed externally on 3 of them and internally with a hex socket through the cut out for the fourth bolt.
Spoke to Alan Henderson today and he reckons it takes approx 1 and a half hours to remove the gearbox with this modification.
Andy
P1060007.JPG and
P1060006.JPG and
P1060003.JPG and
P1060001.JPG and
batfish
