Lotus Elan
Engine and Gearbox for sale
PostPost by: Technical-one » Fri Sep 10, 2021 3:27 pm
I have a Ford 1.8 Zetec engine and MT75 gearbox for sale. When I purchased both units back in the early 1990’s, the engine had recorded 4000 miles and the gearbox has done approximately 5000 miles before being crated up and dry stored to use at a later date.
At the time I had an Elan S3 restoration project sat next to a Lotus Seven S4 chassis. I had acquired a new old stock Lotus Seven chassis missing a few body and suspension parts. After an expensive trip to Caterham and I had sufficient components to complete a sprint/hill climb race car. A short while later a Lotus Seven enthusiast got me to part with the Seven S4 but I keep the engine/gearbox to be used later in a Caterham.
With pair of suitable cams, throttle bodies and ECU, the engine would make good power at a reasonable cost. I should have a prop shaft and gear selector for the gearbox. The engine has all the manifolds, wiring harness, clutch and flywheel.
To install the engine into a Elan Plus 2 Raceline have a parts list that includes water rail and hoses, Weber inlet manifold, wet sump kit, ECU control and wiring.
Engine - £350
Gearbox - £150
07966 610 668
1966 Elan S3 S/E
Technical-one
New-tral
