Lotus Elan
Mainly used parts taking to Castle Combe 29/5 revised
PostPost by: elanfan1 » Sun May 09, 2021 8:29 pm
I’ve started to check out some of the boxes of stuff I have for sale and am planning to bring to Castle Combe. So far I’ve only rooted through one or two and I must have 7/8 in total. I’ll list below what I’ve found so far but intend adding to this over the next couple of weeks.
Please do not ask me to post stuff as at this stage I don’t have the time nor much inclination. If you pay in advance for items I’ll put them aside for you to collect (no payment or I cannot hold for you sorry)
Grey box stuff
One black one white plastic fan blade £10 each
Four timing sprockets. £30 a pair
2 engine sandwich plates £20 each
6 diff tie rods. £10 pair
Clutch fork mechanism. ??
+2 handbrake tree? £10
Rusty battery brackets £1 each
Door lock plates new old stock £10 ea old ones £4 each
+2 aluminium grille. £5
30+ Tenax fasteners. £25
Carburettor connector??
Heater or choke cable with knob £10
+2 gear knob Gaiter. £5
Steering rack Gaiter. £2
Speedo cable. £2
Pulley wheel. £10
Water bottle holders. £10
New old stock in Lotus packaging track rod and these are £96 new £50 plus
Rare red horn relay. ??
Sovy for Phil
Chrome radio speaker grille £50
2 otter switches £10 each
Timing chain tensioner??
23? Drive pegs. £20
Tex flasher unit. £15
Chrome corner windscreen trims ?
Linread door switches. £15 each
Shiny Chrome switch Bezel. £5
Sun visors with brackets £20
Brake dust shields £4 pair
Loose stuff
3 x small Elan radiators £80 each
2 steering racks. £95 each (£245 exchange)
fan motor and 4 blade metal fan. £50 working
Set of Dash ferrules £10
Window cable spool. (£45 Matty). £20
Pair original seat runners. £20
Blue Crate Yellow Barcode
Four track rod ends £10 a pair
Engine mount £5
Framm Air Filter £4
NOS Lucas 8FL36 Flasher £10
Plastic numberplate digits £2 each
Metal numberplate digits £5 each
NOS white lenses £20 pair
AE NOS bearing shells £15
Thermostat £3
Lots of brake pads £5 to £10
Coil £10
Sprockets £10 each
Blue Crate White Label
Wiper motor circular £20
Wiper motor square £20
Bag of bump stops £5
Early oil filter cover £10
distributor cap and cables £15-£20
2 new headlamp bowls £20
old alternator £10
Green Crate
Pair of indicator and headlamp switches
Whiteorange circular indicators £25 a pair
6RA relays £10 each
spring compressor holders £5
fuse boxes £2
Silence is Guildern; Duct Tape is Silver
PostPost by: elanfan1 » Fri May 14, 2021 12:18 pm
I also have upgraded/serviced Philips Turnolock radio and a serviced FM one which I can bring to Combe if anyone wants a looksee. Please let me know in advance.
PostPost by: elanfan1 » Wed May 19, 2021 7:39 am
Managed to go through a few more boxes and have revised the list above.
PostPost by: elanfan1 » Thu May 27, 2021 8:42 pm
Found a couple more interesting bits.
Single window winder motor working £100
Pair of new trunnions £30
