Lotus Elan
Engines and parts thereof
PostPost by: TBG » Mon Apr 26, 2021 2:55 pm
I have a few bits and bobs for sale. Offering on here before going to the dreaded ebay!!
Mk 2 Engine complete less ancillaries. No carburettors, cam cover, flywheel, fuel or oil pumps, front pulleys wheels or distributor.
This engine has an ‘L’ block, steel mains caps, has been line bored,CPL2 cams and a delobed jack shaft.
Pistons are at +040”. Mains and big ends not marked with an oversize , but in good condition. Was running perfectly, removed to replace with 1700 engine.
and - Mk 2 Rotating assembly. An ‘L’ block, crank, rods pistons, rear oil seal housing.
Pistons at +015”. Mains at 030”. Big ends at 020”. No 1 big end shells worn.
I have the odd oil pump and distributor and possibly a fuel pump. Also a front cover.
All here in Somerset for viewing and so on. D
TBG
PostPost by: tonyabacus » Fri Apr 30, 2021 4:00 pm
Whereabouts in Somerset.
Can you send me a pm with details of what cost for the two units please
Tony
tonyabacus
PostPost by: TBG » Fri Apr 30, 2021 5:43 pm
Tony PM sent, D
TBG
PostPost by: TBG » Mon May 03, 2021 10:05 am
Rotating assembly gone - engine still here at the moment. D
TBG
