Lotus Elan
Solid Driveshafts for Elan
PostPost by: bitsobrits » Mon Jun 15, 2020 1:11 am
Steel u-joint style solid driveshafts for 2 seater Elan. Stamped GKN on yokes. Splines seem to be in good shape and U-joints have no discernible play. Oddly, 3 of the 4 adaptor plates are drilled for both very early S1 stub shaft PCD and later S1-S4 style. Includes AN bolts and nuts. $200 obo.
IMG_0295.jpeg and
IMG_0296.jpeg and
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: nmauduit » Mon Jun 15, 2020 8:38 am
PM sent thank you Nic
S4SE 36/8198
PostPost by: rgh0 » Mon Jun 15, 2020 2:12 pm
The TTR shafts I believe are drilled for both PCD's. Looks like one was replaced without the dual drilling or if it was missed in original manufacture. The right side shaft in the photo appears to not be properly aligned either with the sliding spline out a tooth for alignment of the yokes on the intermediate shaft which also suggests a replacement at some time.
PostPost by: john.p.clegg » Mon Jun 15, 2020 2:34 pm
Not much gets past you does it Rohan ?
John ;-)
PostPost by: rgh0 » Mon Jun 15, 2020 3:00 pm
john.p.clegg wrote:Not much gets past you does it Rohan ?
John ;-)
:lol: I spend to much time looking at broken bits I think
PostPost by: HCA » Mon Jun 15, 2020 5:10 pm
rgh0 wrote: with the sliding spline out a tooth for alignment of the yokes on the intermediate shaft.
:) :wink: :wink:
HCA
PostPost by: bitsobrits » Mon Jun 15, 2020 6:59 pm
If it's out of alignment it's no doubt from slipping them apart to show the splines.
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: Gurty » Sat Jun 20, 2020 8:10 pm
I'm interested in the driveshafts. Do you have an email i can contact you on regarding them?
Would you take $200 including shipment to the UK ?
Thanks, Graham
Gurty
New-tral
PostPost by: bitsobrits » Sun Jun 21, 2020 3:01 am
The driveshafts have been sold. Based on all the interest I received, I should have raised the price :D
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
