Lotus Elan
Lucas c40
PostPost by: SENC » Thu Apr 30, 2020 2:17 am
Does anyone have an old c40 generator collecting dust they're willing to part with? I'm looking for one to rebuild.
Henry
69 Elan S4
65 Seven S2
PostPost by: gherlt » Thu Apr 30, 2020 7:20 am
I got one .. somewhere ... but .... your location "NC" is Noth Carolina ?
1964 S1 (engine ready, awainting body paint)
1967 S3 DHC (now adjusted by Brian Buckland, totally calm idle)
1969 S4 FHC (final interior stuff)
gherlt
PostPost by: alan.barker » Thu Apr 30, 2020 8:13 am
Be careful there is the C40 and theC40L. They are not the same Length and different Bracket needed :wink:
PostPost by: elanfan1 » Thu Apr 30, 2020 9:21 am
Think Henry needs one from USA as shipping internationally alone would probably be cost prohibitive.
Silence is Guildern; Duct Tape is Silver
PostPost by: alan.barker » Thu Apr 30, 2020 9:54 am
If for sure it's the C40 which is the short one you can find this on almost any old british classic car.
Mini, triumph spitfire, mgb, mg midget etc.
PostPost by: SENC » Thu Apr 30, 2020 10:46 am
Yes, C40 and yes, North Carolina in the US - so shipping from overseas likely doesn't make any sense. I will do a local salvage yard search, too, but thought I'd ask here at the same time.
My 7 is still on dynamo and I've never worked on one, so thought I'd try to find an old one to rebuild and learn from next off season.
Henry
69 Elan S4
65 Seven S2
PostPost by: gjz30075 » Thu Apr 30, 2020 12:03 pm
PM sent.
Greg Z
45/0243K Sprint
36/5727 pre airflow coupe
PostPost by: Mike Ostrov » Thu Apr 30, 2020 1:34 pm
Hi, Henry. Dont forget to polarize the dynamo after re furbishing. I bench test all mine with an analog (moving coil) meter. I also suggest you use studs in place of the bolts to secure the dynamo bracket to the block Amazing how many brackets I have seen, broken and loose. I use Loctite red stud and bearing #241.
Every stud on my Coventry Climax engines are installed with #241 and same for our alloy differential case. Bolts into alloy and cast iron, other than first application are not the best method.
One more month of lock down in our San Francisco Bay Area, but a drive today or tomorrow around the reservoir, probably in the Automatic Elite/Elan 1725 cc Twin Cam is on the schedule with the guys. Cheers. Mike.
[email protected] or (5l0) 232-7764
Mike Ostrov
PostPost by: SENC » Thu Apr 30, 2020 6:53 pm
Need fulfilled and another reason to love this site, thanks Greg!
Thanks Mike for the tips, too.
Henry
69 Elan S4
65 Seven S2
