Lotus Elan
Final drive casing and inner d/shafts
PostPost by: promotor » Sat Nov 23, 2019 4:01 pm
Late type final drive casing ie with big ears.
All good threads for brass plugs as well as the 8 mounting bolt holes.
No repairs been done.
Circlip grooves good condition.
Has been vapour blasted not too long ago.
Has a bit of damage inside near a bolt hole - this is near to a bolt hole but doesn't leak - I've put thinners inside the hole and it doesn't seep through.
dsc05998.jpg and
dsc05999.jpg and
dsc06000.jpg and
dsc06001.jpg and
dsc06002.jpg and
?135 + post for the casing.
Driveshafts - these are the later, thicker type.
They were safety spec shafts which have had part of the stub removed for use in non-safety spec set-up. Could use as is but ideally need cutting down / tidying up.
Good condition splines and oil seal surfaces.
Bearings could do with replacing.
dsc06004.jpg and
dsc06005.jpg and
dsc06006.jpg and
dsc06007.jpg and
?85 + post.
promotor
PostPost by: alanr » Sat Nov 23, 2019 4:19 pm
I would like the Driveshafts please. PM sent.
Alan.
'71 +2 S130/4
PostPost by: promotor » Tue Nov 26, 2019 7:04 pm
alanr wrote:I would like the Driveshafts please. PM sent.
Alan.
Now on their way to you Alan. Cheers for your purchase!
promotor
PostPost by: l10tus » Wed Nov 27, 2019 3:22 pm
Can I buy the diff case please?
Philip.
UK '72 Sprint DHC
l10tus
PostPost by: promotor » Sat Dec 07, 2019 8:56 pm
Thanks for the interest, the final drive casing is now sold.
promotor
