Lotus Elan
Gearbox parts
PostPost by: miked » Thu May 02, 2019 8:20 pm
Hi, I have decided to clear out some of my gearbox parts. Was going to put some together but changed my mind. I am not going to Castle Combe but my good friend Greg is. He will take them boxed up separately with Name and price if anybody has bought them.
Will post here separately. I would prefer they are picked up at CC for bigger items. Will post at your cost but will not be working out how much to all sorts of locations. Not being funny but it costs what it costs. I use Hermes and think they are very reasonable.
First is 2000e semi close ratio gear set complete with main shaft, first motion shaft, lay gear, needles and shims. Both bearings and rear bearing carrier. This is lock nut type shaft. Not snap ring.
I will leave 1st/2nd gear synchroniser hub and rings on to save taking apart.
The internal surfaces of the lay gear and 1st motion shaft are clean and not corroded. As is the end of the main shaft bearing. All gear teeth are in place. What you see is what you get.
?130.00 SOLD SOLD
Cheers Mike
img_0021.jpg and
img_0018.jpg and
Elan S4 Zetec
BSA B33
Suzuki Hustler T250
BMW rninet scrambler
Suzuki TC120R trailcat
Suzuki TC120 trailcat
Suzuki K11 super sport
miked
PostPost by: promotor » Thu May 02, 2019 9:26 pm
PM sent
promotor
PostPost by: Kpas » Fri May 03, 2019 9:02 am
Pm sent
Kpas
New-tral
Users browsing this forum: gino1 and 5 guests
