Lotus Elan
s2?????
PostPost by: gino1 » Wed Jan 02, 2019 4:10 pm
Could be something to do with two inspection holes for setting vernier pulleys ?? the mind boggles... :?
On another point I have a Marston radiator fitted on my cars and some have the corners chamfered and some dont... was this one shown in the picture a later one ??
Gino
Milano
italy
1965 Elan S2 Roadster
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: Certified Lotus » Wed Jan 02, 2019 4:27 pm
Those ?things? on the cam cover are oil breathers. I have the same on my S2, but only one of them. I thought it was custom but now know someone was making them at one point in time. They are welded onto the cam cover. I wonder who was making them back in the 70?s?
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: nigelrbfurness » Wed Jan 02, 2019 7:12 pm
I was wondering about those handles on the front of the cam cover too. The car has S1 window lifters but an S2 dashboard. There were some late '64 S1s made with S2 some features, could be one of those but a replacement crashpad and dashboard for an S2 will fit an S1 shell so could have been fitted quite recently. The seats are incorrect too and the steering wheel is from an S4.
Whether or not its a bargain depends on what it fetches. At the moment it is only bid to around 10K USD which is cheap for an early car. It has the makings of an easily restorable project for an early series car.
If it was in the UK I'd be looking at it.
Nigel F.
nigelrbfurness
PostPost by: groucho » Wed Jan 02, 2019 9:08 pm
I'm pretty sure that's a homemade replacement dash. My dash is similar, made by a previous owner out of marine plywood. If the original S1 glovebox was damaged and the original dash worn out, it's probably easier to just build an S2-style dash.
No trunk photos, either... just an upside-down picture of the inside of the trunk lid, with what appears to be a broken tab on the locking mechanism. No armrest padding, either. Lots of strange things with this car.
IMHO, the current bid price is crazy cheap, though, for a running/driving S1. I'm sure it'll jump up closer to the end of the auction.
Jeff Kyle
1965 Elan S2
2005 Elise
groucho
PostPost by: nomad » Wed Jan 02, 2019 9:43 pm
May not be so cheap considering how many things that are wrong about this car. Just about every where you look. When it would have been no more difficult to make things close to right! Scares me as to how much more isn't right that the seller isn't mentioning or showing. Currently about the right price for a restoration candidate and that is really what it should be.
That Dash! Looks to be a piece of veneered sawdust board!
Kurt
nomad
PostPost by: gjz30075 » Wed Jan 02, 2019 9:44 pm
Breathers.
Greg Z
45/0243K Sprint
36/5727 pre airflow coupe
PostPost by: nomad » Wed Jan 02, 2019 10:04 pm
My question's about the frame turrets and whether or not the car even has a heater since it obviously isn't hooked up, are apparently going to go unanswered. As well as what he encountered with the lattice work in the body while it was being restored.
Kurt
nomad
PostPost by: StressCraxx » Wed Jan 02, 2019 10:09 pm
I thought the breathers looked really familiar. Back when dinosaurs roamed the earth and rail dragsters had the engines mounted in front with the driver straddling the diff and transmission, I sold aircraft quality aluminum and alloy steel tubing to places like Moon Equipment Company in Santa Fe Springs.
You can still buy them! http://www.mooneyesusa.com/category-s/191.htm
The Twinks seemed to be built pretty loosely and the lone vent at the rear of the head behind the intake runners was a bit on the small side. So many owners and engine builders installed these to the head to keep from pushing oil out through the crank seals, timing chest and cam bore plugs. I have seen a few Twink powered vintage race cars with them. The owner of this car could add the "Moon Equipped? sticker to his car or toolbox!
http://www.mooneyesusa.com/Moon-Equipped-Stickers-Decals-s/93.htm
StressCraxx
PostPost by: vstibbard » Sun Jan 06, 2019 11:34 am
period mod they are cam cover breathers
V
PostPost by: groucho » Sun Jan 06, 2019 2:12 pm
Sold, $21,760. Not a screaming deal but still a pretty good deal for an Elan S1 in 2019, IMHO, assuming the buyer is looking for a driver and not a perfect restoration.
Jeff Kyle
1965 Elan S2
2005 Elise
groucho
PostPost by: rcfurse » Sun Jan 06, 2019 2:43 pm
And look at the exhaust manifold. Weird too.
Richard Furse
Funemployed in N Wales
S3 DHC
S4 DHC
S4 FHC
S4/Sprint
340R
SID
14 "others"
rcfurse
PostPost by: knockoffnut » Sun Jan 06, 2019 3:02 pm
that actually looks like a correct S1 exhaust, and early head casting too. The car was posted as an S2 but is actually a late run S1...
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
knockoffnut
PostPost by: tedtaylor » Sun Jan 06, 2019 6:20 pm
the deal breaker for me (even though i'm not wanting the car myself) is that FUNKY cat fish front mouth treatment. No one here is discussing that atrocity?
TED
tedtaylor
PostPost by: groucho » Mon Jan 07, 2019 6:51 pm
tedtaylor wrote:the deal breaker for me (even though i'm not wanting the car myself) is that FUNKY cat fish front mouth treatment. No one here is discussing that atrocity?
ACK! I hadn't even noticed that! That is ghastly. They turned the Elan smile into a frown! Why in the world was that done........?
Jeff Kyle
1965 Elan S2
2005 Elise
groucho
PostPost by: bitsobrits » Mon Jan 07, 2019 8:31 pm
Hence my comment back on the 31rst that it appeared the car was crying....because it was so poorly "restored".
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PreviousNext
