Lotus Elan
Parts for sale
PostPost by: englishmaninwales » Mon Oct 08, 2018 11:54 am
A bit of a clear out after changing from a 4 bolt crank to a 6 bolt crank and various other jobs.
All items plus P+P
Items for collection, located at LL16. (NE Wales UK).
4 bolt flywheel, genuine T/C, starter ring and clutch face in good condition, genuine T/C 4 bolt crankshaft 020/020 undersized. This will require a re-grind on both pins and journals. These are ideally sold together as they are a balanced pair (sorry, no clutch cover) ?50 for the pair, or will split.
Ideally, collection as heavy!
QED crank pulley. This was trial fitted only, but unused, minor witness marks from woodruff key. Includes new unused QED washer, no bolt, ?35 (normally together ?50 incl vat).
Rear crank seal housing, used genuine Ford, suits 4 bolt crank. ?5.
Spigot bearing, brass (not Oilite). New unused. Suits 4 bolt crank. 40mm OD 15mm ID ?20.
Set of 4 QED conrod small ends. New unused, in original packaging. ?25 (normally ?33.60).
QED oil pick up, later push in type. New unused ?40 (normally ?59.40).
Oil pick up gauze bowl, used genuine Ford, suits previous item ?10.
Engine to bellhousing sandwich plate, used, genuine Ford, suits 4 bolt crank ?10.
Sump gasket set, Burtons still in original packaging, suits 4 bolt crank ?10 (normally ?13.60).
Coolant pump pulley flange, Burtons, new unused ?8 (normally ?11.21).
Thanks for looking.
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
