Lotus Elan
Plus 2 Parts - Seats, Doors, Pedal Box, Wishbones, ++++++
PostPost by: Elanintheforest » Sat May 12, 2018 3:29 pm
I?m having a bit of a clearout of Elan Plus2 bits and pieces that I won?t need for my car. I?m starting a new project so need some space!
Most of the items are for collection only, unless it says ?will post? next to the item. I?m in Gloucester in the UK.
Due to a broadband grinding to a halt here in the sticks I'm adding photos ....slowly!
I'm open to offers if you want lots of bits!
Early Elan Plus 2 Seats
********* SOLD ***********
?190
These are in reasonable original condition but will benefit from being re-covered.
The frames are the same as the 2 seat Elan frames, but modifications have to be done to the mounting area to fit into a 2 seater.
They have their original mounting and sliding frames fitted.
dsc_0033.jpg and
Early Elan Plus 2 Doors (x 3)
?260
I bought these as spares for the doors of the early cars are getting really hard to find. With this lot you get a complete set and a fair bit more!
These are 2 x Passenger doors and 1 x Driver s door. The 2 green doors were off the same car.
Door 1 ? Passenger green door. The fibreglass is a bit butchered where the internal door opening mechanism bolts to it. It also doesn?t have the drop glass or the internal door opening mechanism, but does have everything else, including a good frame, window motor, hinges, chrome waist strip etc.
Door 2 ? Passenger blue door. The fibreglass is in good condition, but the door is missing the external handle. It is otherwise complete.
Door 3 ? Driver green door. Complete.
dsc_0006.jpg and
dsc_0007.jpg and
dsc_0005.jpg and
dsc_0008.jpg and
dsc_0009.jpg and
dsc_0011.jpg and
dsc_0012.jpg and
dsc_0014.jpg and
Early Elan Plus 2 bood lid)
?15
Good fibreglass.
dsc_0002.jpg and
Last edited by Elanintheforest on Thu Aug 16, 2018 7:45 am, edited 3 times in total.
PostPost by: Elanintheforest » Sat May 12, 2018 3:43 pm
Limit of 10 photos hit, so here area few more items....
Elan Plus 2 headlamp pods
?50
These both have good fibreglass. One looks like it?s cracked in the photos, but that?s just where paint and a very thin layer of filler has lifted.
dsc_0040.jpg and
dsc_0041.jpg and
Elan Plus 2 Inertia seatbelts
?100 !!!!!!!!! SOLD !!!!!!!!!!!
These are in superb cosmetic condition. The red ?Press? button is a very bright red?obscured by the sticker! The webbing is also very good.
img_8666.jpg and
img_8665.jpg and
Elan Plus 2 ?S? Pedal Box
?320
This was professionally restored about 10 years ago, and looks superb.
img_8652.jpg and
img_8657.jpg and
img_8656.jpg and
Elan Plus 2 ?S? Steering column
?190
This is complete with brackets, indicators stalk, headlamp dip stalk and lock with key, and is in good condition. I think you could use this to ?upgrade? an earlier car with the collapsible column.
img_8671.jpg and
img_8672.jpg and
img_8674.jpg and
Last edited by Elanintheforest on Thu Aug 16, 2018 7:47 am, edited 3 times in total.
PostPost by: Elanintheforest » Sat May 12, 2018 3:50 pm
Elan Plus 2 Front Wishbone set
?90 ---------SOLD-------------
In very good condition.
img_8660.jpg and
Elan Plus 2 Remote boot opening bracket and mechanism
?75
Some surface rust on the bracket, otherwise very good.
img_8679.jpg and
img_8680.jpg and
Elan Plus 2 door check-straps
?75 will post ---------SOLD-----------
These are in good condition with a little surface corrosion, mainly underneath.
img_8662.jpg and
img_8664.jpg and
Elan Plus 2 Bonnet Catches
?15 will post
These are for refurbishment
Elan Plus 2 Boot lid hinge reinforcement bar (x 3) and external lock set
?15 each for hinge reinforcement bars,
?90 for external lock set.
One very early reinforcement bar with round tubing, needs a couple of attachment brackets welding on
The long bracket on the early Elan Plus 2 rear of boot long bracket and lock / catch / bracket set is quite rusty but may be saveable. The prize is the lock / catch / bracket mechanism.
img_8675.jpg and
img_8676.jpg and
img_8677.jpg and
Last edited by Elanintheforest on Tue May 15, 2018 6:55 am, edited 2 times in total.
PostPost by: Cymru » Mon May 14, 2018 12:02 am
HI,
PM sent re the Elan Plus 2 door check-straps.
Rod
Cars:
Restoring
69 Elan +2
Running
73 Europa Special
Cymru
First Gear
First Gear
