Lotus Elan
A few more bits from the 27 foot Lotus container
PostPost by: Mike Ostrov » Thu Apr 19, 2018 2:18 pm
Spring time clean up, so,hope you can use something.
1. last pair of NOS rear brake disks
2. complete rear brake calipers with handbrake stuff
3. S1/S2 LHD tonneau cover - original
4. many front brake calipers
5. +2 boot lid, yes a +2
6. boxes of front suspension parts
7. pair of rear 4 bolt on hubs-tested and true
8. under the dash pull handbrake assembly
9. many Twin Cam parts to build a complete engine
10. Front and rear used KONI's - excellent condition
11. Issue 16 rear uprights, bare
12. 3.77 diff (no pinion flange) and 3.90 diff
13..Stromberg air box tube to head
14. huge inventory of Type 14 Climax Elite parts
15. Some Seven stuff (rear original axle, front suspension )
16. 1600 x flow weber intake manifolds (short and long runners)
That's it till the next clean up session. Cheers. Mike at 510-232-7764 (Richmond, CA) or [email protected]
[email protected] or (5l0) 232-7764
Mike Ostrov
PostPost by: Cymru » Thu Apr 19, 2018 9:03 pm
The front and rear used KONI's - are they for a +2
If yes - what would you take for them?
Cars:
Restoring
69 Elan +2
Running
73 Europa Special
Cymru
First Gear
First Gear
PostPost by: Famous Frank » Thu Apr 19, 2018 10:55 pm
Mike,
PM sent regarding the Tonneau.
Thank you,
Frank
Famous Frank
66 Elan S2 SE
65 Elan S2
66 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank
PostPost by: nmauduit » Fri Apr 20, 2018 7:46 am
Hello Mike,
PM sent regarding item #13
thank you
S4SE 36/8198
PostPost by: el-saturn » Fri Apr 20, 2018 11:59 am
hi mike - i need a pair of lower wishbones for a s3 elan (reinforced ones if possible with the additional collar where the bush is) - they'd have to be real nice!! pls pm me a price tx sandy
PostPost by: SprogBarnes » Fri Apr 20, 2018 6:11 pm
Hi Mike, I know its not on the list but if you have a Plus 2S astray handle (door) I'd love to take that of your hands hands.
Thanks!
SprogBarnes
First Gear
First Gear
