Lotus Elan
High balance tube manifold for twin cam engine
PostPost by: arcangel » Thu Feb 22, 2018 9:04 pm
HBT manifold for sale
I'm offering for sale one pair of high balance tube manifolds for the twin cam Lotus engine. I had two pairs made (minimum number my machinist will accept for a production run), need only one pair for now. Designed to replicate the non emissions intake manifold, it is machined from aluminum billet and tubing and is a direct bolt on for the federal twin cam Europas and Elans. To save labor costs only minimal finishing work was done. The surface finish is acceptable but some may want to have additional polishing done.
What is included:
1. (1) left and (1) right manifold
2. (1) balance tube
3. (2) screw in hollow plugs
4. butyl sealing ?O? rings for the balance tube
Asking $400 for the pair.
Joji Tokumoto
Fallbrook, Ca
hbtm-14-copy.jpg and
hbtm-13-copy.jpg and
hbt-3.jpg and
hbt-2.jpg and
hbt-1.jpg and
arcangel
First Gear
First Gear
PostPost by: bahama61 » Mon Apr 09, 2018 11:10 am
Hi.
I?m after some belmouths for my Strombergs.
Where did you get yours.
Are they still available.
Thanks Phil
bahama61
New-tral
PostPost by: The Veg » Mon Apr 09, 2018 1:55 pm
Joji,
If you haven?t had any takers I might be interested, but at a significantly lower price (no offense intended, just my personal priorities).
Phil, I don?t know about those particular bells but RD Enterprises have some different ones for Strombergs.
1969/70 Elan Plus 2 (not S) 50/2036
The Veg
PostPost by: lotus66 » Sun Apr 15, 2018 5:33 pm
Hi, like to pick up your intakes. Please let me know, Jim 240-626-9032. EST, give me a call!!!
lotus66
First Gear
First Gear
PostPost by: 69S4 » Sun Apr 15, 2018 5:41 pm
Is there any advantage to having a high level balance tube over the mid level one I've got?
Presumably the plastic plugs are needed as a result of machining the manifolds?
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: arcangel » Thu Apr 19, 2018 1:36 pm
bahama61 wrote:Hi.
Thanks Phil
Phil, the bellmouths/trumpets came with my Strombergs, I plan on keeping them. I do not know where thy came from but Pegasus sells them.
https://www.pegasusautoracing.com/produ ... RecID=5142
Joji Tokumoto
arcangel
First Gear
First Gear
PostPost by: arcangel » Thu Apr 19, 2018 1:40 pm
The Veg wrote:Joji,
Unfortunately, the price I'm asking is what I paid my machinist for the HBTM. If 'm not able to sell them, they will go on my TCS Europa. The first one is for the Plus 2.
arcangel
First Gear
First Gear
PostPost by: arcangel » Thu Apr 19, 2018 1:45 pm
69S4 wrote:Is there any advantage to having a high level balance tube over the mid level one I've got?
As far as I'm aware the only advantage to having the tube at mid level is probably the ease of machining the passages. The high balance tube requires a right angle attachment or in my case drill the hole from the bottom and to get access to the top and then plug up the bottom hole.
arcangel
First Gear
First Gear
