Lotus Elan
New Elan Plus 2 Alloy Wheels
PostPost by: danielmo » Mon Oct 02, 2017 3:12 am
I bought these wheels from a forum member, but have decided not to use them. They are new, with a couple of scratches from storage. They are missing the center lock rings. They might be available from Panasport or Minilite, now that they are making center lock wheels again. $800/set plus shipping from 98296.
img_8860.jpg and
img_8861.jpg and
img_8862.jpg and
img_8863.jpg and
img_8864.jpg and
danielmo
PostPost by: Lotusdavid » Wed Oct 18, 2017 12:28 pm
what part is missing?
Lotusdavid
First Gear
First Gear
PostPost by: danielmo » Wed Oct 18, 2017 2:34 pm
I think there is a center ring that is supposed to go in the middle of the wheel. That is what is missing.
danielmo
PostPost by: Lotusdavid » Wed Oct 18, 2017 2:41 pm
I just compared a pic of your wheel with one at Kelsport in UK.
The have brand new wheels, and they appear to have a ring
of some sort that the wheel nut bears on. Looking to see if
they have that separate
Lotusdavid
First Gear
First Gear
PostPost by: theelanman » Wed Oct 18, 2017 7:54 pm
Yes you will need a collar to fit inside and give you a hard face..........they are available......
theelanman
PostPost by: The Veg » Mon Oct 23, 2017 9:29 pm
As an aside, does anybody know if that ring-insert is the same or different to the ones used with Revolution wheels?
1969/70 Elan Plus 2 (not S) 50/2036
The Veg
PostPost by: prezoom » Tue Oct 24, 2017 2:37 am
I have wondered if the new replacement rings are compatible with KO nuts as found on US Plus2s with steel wheels? My KO's have cast into the nut, that they are not to be used with alloy wheels.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: el-saturn » Tue Oct 24, 2017 11:16 am
i'd say, without putting to much thought into this: the ring A) disributes the tightening and movement loads and B) will certainly make the use of the "wrong" nuts possible. the wear on a steel wheel is by no means evenly distributed as you cab see for yourself - sandy -- PS: i even have a set of 4,5inch brand rims which wear-wise look similiar (1kg less than a orig. steel = 4kgs!!! or a tenth amywheres!!)
PostPost by: jnkiliany » Fri Feb 16, 2018 7:48 pm
Hi, are these rims still for sale?
jnkiliany
New-tral
PostPost by: danielmo » Mon Feb 19, 2018 3:56 am
Yes, still available.
danielmo
PostPost by: jnkiliany » Thu Mar 01, 2018 12:06 am
Danielmo, will you call me at 909-987-4289 to discuss your wheels.
James.
jnkiliany
New-tral
PostPost by: jnkiliany » Thu Mar 01, 2018 12:13 am
Is there a member that would loan me a collar for the 10 rib alloy wheel so that I can have some copies made? I will pay for shipping and a deposit if that would help. Prefer state side transaction. Thanks
jnkiliany
New-tral
