Lotus Elan
Garage clear out in North Yorkshire
PostPost by: rogersste » Mon Jan 02, 2017 7:15 pm
I have decided its time to clear out the garage!
The following parts are surplus to requirements, they came off my Series 3 DHC when I rebuilt and upgraded it about 5 years ago - the chassis, brakes, suspension and engine were all rebuilt and many standard items replaced. Some bits will need refurbishing and some probably would be best consigned to the dustbin (eg the donuts).
I have photos of just about everything.
I plan to put them on eBay, but if anyone here is interested please contact me.
I am based in North Yorkshire in the UK.
Brake parts
2 x Front brake calipers, complete with pads, pins and mounting plate
2 x Front disc dust plates
4 x Front discs
Brake master cylinder
Girling brake servo plus mounting bracket
Suspension parts
4 x Front suspension units (spring plus shock absorber)
2 x Rear suspension units (Issue 16) complete assembly with hubs and shock absorbers SOLD
2 x Rear springs plus caps
2 x Rear wishbones
Transmission
2 x Drive shafts
4 x Donuts
Prop shaft SOLD
Gearbox mounting plate
Clutch master cylinder
Twin Cam engine parts
Crankshaft (early 4 bolt rope seal type) SOLD
Flywheel (4 bolt) SOLD
Set standard pistons and con rods SOLD
Standard valves and springs SOLD
Timing chain SOLD
Early type sump SOLD
Rear oil seal cover plate SOLD
2 x Oil pump and filter bowl ONE SOLD
2 x Mechanical fuel pump with glass bowl filter
Electrical
Lucas dynamo with pulley and mounting bracket SOLD
Lucas electric control box SOLD
Lucas starter motor SOLD
Starter motor solenoid plus lead SOLD
Kenlowe electric fan with mounting bracket
Other
Radiator SOLD
I may find some other bits and pieces...
1966 Elan S3 SE DHC
rogersste
New-tral
PostPost by: s28ven » Mon Jan 02, 2017 10:30 pm
Steve, what condition is the servo in? How much would you be looking for it?
Steven
s28ven
PostPost by: Jentwistle3 » Wed Jan 04, 2017 2:49 pm
Hi Roger
I am interested in the sump if it still available. Can you please PM me details?
Jentwistle3
PostPost by: el-saturn » Thu Jan 05, 2017 8:58 pm
the main gearbox shaft you've added: is that the main shaft with 4th gear?? if it is could you email me a picture to [email protected] muchas gracias sandy
PostPost by: englishmaninwales » Fri Jan 06, 2017 7:13 am
I have sent you a PM about the rear suspension components and propshaft.
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
Users browsing this forum: cleaver and 5 guests
