Clutch release bearing carrier
PostPosted: Mon May 30, 2016 7:55 pm
by worzel
Just found this item- this was the original type bearing carrier for the release bearing that came with my sprint 38 years ago. I replaced it with the one Paul Matty sells which is a different size- needlessly as it happens as the bearing itself has covered only about 800 miles or so (I was replacing the 2nd gear synchro at the time hence the removal).
So if you're looking for the original type carrier plus a hardly used bearing make me an offer.
regards
