Lotus Elan
Clutch release bearing carrier
PostPost by: worzel » Mon May 30, 2016 7:55 pm
Just found this item- this was the original type bearing carrier for the release bearing that came with my sprint 38 years ago. I replaced it with the one Paul Matty sells which is a different size- needlessly as it happens as the bearing itself has covered only about 800 miles or so (I was replacing the 2nd gear synchro at the time hence the removal).
So if you're looking for the original type carrier plus a hardly used bearing make me an offer.
regards
worzel
Users browsing this forum: Bank16 and 9 guests
