Lotus Elan
various bits for sale
PostPost by: Mike Ostrov » Tue May 17, 2016 10:12 pm
1. S2 fuel gauge #FG2530/71 complete,ready to install and tested, beautiful. 2. handbrake T handle assembly, complete with switch 3. complete set of rear calipers 4. S4 heater box, tested at 12 psi 5. dual gauge 0 -60 psi and 0 - 110F needs repaire 6.one 4 bolt steel wheel 7. one +2 rear trunk lid 8. full sets of stock cams and two sets of performance Kenny Harmon KH 1 and KH 2 cams 9. L blocks and many engine parts 10. Five (5) American Racing Silverstone Mag wheels, complete, 5 inch rim, yes, the real deal.and very $$$$$ 11. Four (4) Western alloy rims at 6 inch, currently fitted with 205 x 13 Goodyear Wingfoot tires. A bit much for an Elan.but not so $$$$. Might be more stuff in the 27 foot Lotus storage container and will check after the first of my two annual open house shop days/BBQ/Weber instruction by Keith Franck/composite repair seminar/swap meet and more this Saturday 21 May. Mike at: 510-232-7764 or [email protected]
[email protected] or (5l0) 232-7764
Mike Ostrov
PostPost by: Pastapesto » Tue May 17, 2016 11:16 pm
PM sent......
Pastapesto
PostPost by: olivier » Wed May 18, 2016 6:24 am
I have sent a email for the rear calipers
olivier
PostPost by: 661 » Wed May 18, 2016 8:02 am
PM sent re handbrake
Graeme
S4 SE
S2 GTS
Peterson JPS Exige
PostPost by: seniorchristo » Wed May 18, 2016 11:53 am
Hi Mike
I have KH2 cams in my S3. I can describe their characteristics as follows: . 360" of valve lift. Pulls very strong from 2500 to 6500 rpm. Smooth idle at 900 rpm. Some hesitation off idle to 2500 rpm which I think could be corrected with proper carb jetting. I wish your Weber seminar wasn't 3000 miles away. :roll: These cams are probably similar to Sprint cams. I hope to degree them sometime soon and will report the results.
Chris :)
67 Elan Super Safety
67 Elan +2
PostPost by: Mike Ostrov » Wed May 18, 2016 1:32 pm
Hi, Guys. Just a request to please contact me directly at: [email protected]. My 1996 antique webtv many times does not work well with the forum reply or private message system, so, apologies to anyone I have not replied. Also, forgot to add to the list: 4 re chromed original hub caps. Beautiful with just a few small scratches from sitting for over 20+ years. Plus, many suspension parts, front and rear. Thanks for your interest.
Cheers. Mike
Mike Ostrov
PostPost by: Mike Ostrov » Wed May 18, 2016 4:30 pm
Hi, Chris. Thanks for the specs. I found the yellow KH tags for each cam. .388 lift of the KH 1. Could be a fun boy racer street cam. You can still pop out, our Weber Wizard Keith Franck will be on site. Cheers. Mike
Mike Ostrov
