Lotus Elan
FS: Gearbox - Dummy Layshaft
PostPost by: 65 Lotus » Wed Dec 09, 2015 12:39 am
Dummy layshaft for installing the laygear (cluster gear) assembly in the Elan gearbox during rebuild for sale, $50.
I had the shaft made when overhauling a gearbox. Centerless ground to 0.678" with a hole through the middle of the shaft for expelling air. Perfect length and size, made from 4340 steel. Works as prescribed.
Will ship to the lower 48 for $50.
Scott in Ohio
Scott In Ohio
26/3795
65 Lotus
PostPost by: lotusgagne » Mon Dec 14, 2015 10:34 pm
PM sent a few days ago to Scott in Ohio, no response yet. Scott, are you still there?
Claude
lotusgagne
First Gear
First Gear
PostPost by: Chancer » Tue Dec 15, 2015 10:34 am
My dummy layshaft I made from an old layshaft cut down to the required length, I then laboriously reduced its diameter by rolling it against the wheel on a bench grinder until it would pass through the interference fit part of the gearcasing, it works a treat but given the time taken yours is well worth the price.
Also its much more pleasant to work with a precision manufactured tool than a real lash up that would have no place in a pro workshop.
Chancer
PostPost by: 65 Lotus » Tue Dec 15, 2015 10:29 pm
I'm here. Sorry, had to leave on an emergency trip to the folks. Back now though...
PM'd, and thanks!
Scott In Ohio
26/3795
65 Lotus
