Lotus Elan
Big Valve Sprint head, new powermax pistons +++++
PostPost by: bigvalvehead » Wed Apr 01, 2015 8:43 pm
Having a major clearout will post pics and full list in next few days.
Items include
Bigvalve Sprint Weber head
Pair DCOE 40 carbs
Set +40 brand new powermax pistons, large valve cutouts.
Mk1 Cam cover
701m Block
Plus race spec engine with fully ported head, forged pistons 701m block, 45 DCOE webers, dry sumped, lightweight flywheel.
Water pump covers including Europa water pump, some with tooth belt drive , Chronometric tacho drive.
[email protected]" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank
Dave Hughes
3 Heads as follows
Head 1 Blue hammerite in pics
Big Valve head with valves, buckets, springs, retainers, no collets,(all unknown)
Thickness 4.618 has some light peppering on no 2 cylinder inside gasket area.
?1250
Head 2 Silver paint in pics
Not N stamped but bigger valves than bigvalve 1.6 inlets 1.37 ex. 4..63 thick excellent head.
with valves, springs, retainers, buckets (all unknown )
?1250
Head 3 bare in pics[u] SOLD
[/u]Big valve head with N stamp. no valves. Head thickness 4.618 needs a skim
?1000
Engine
701m Block, balanced crank and rods, forged pistons, Burton lightweight flywheel with sintered clutch,
Distributor, Steel dry sump pan.
Head 1.38 ex valves 1.61 inlets, polished for 45 dcoe carbs, L1 cams.
Comes with pair of Italian 45 DCOE carbs just needs dry sump pump
Has new Dry sump cam cover (choice of BRM Early type or MK1 )
?3500.
Set of new powermax pistons +40 complete with rings , pins and clips ?350
20150402_123404.jpg and
20150402_123349.jpg and
20150402_123342.jpg and
20150402_123055.jpg and
20150402_123024.jpg and
20150402_122936.jpg and
20150402_122924.jpg and
20150402_122710.jpg and
20150402_122648.jpg and
20150402_122631.jpg and
Dave Hughes
S2 26R
Elan DHC Sprint
bigvalvehead
PostPost by: john.p.clegg » Thu Apr 02, 2015 5:40 am
Open the floodgates.....
John :wink:
P.S. Did i buy some parts off you many years ago to do a tall block conversion? approx1998?
